Kettler Rivo P Elliptical Cross Trainer Exercise Machine 7644-000 Logo
G
Gerard Mulqueeney Posted on Oct 12, 2016
Kettler cross trainer is jammed solid. How could I fix this
Have taken off the one guard. Belt seems to be in place and intack. Don't know what to do now
2 Related Answers
Anonymous
  • Posted on Jan 16, 2011
SOURCE: Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
Anonymous
  • Posted on Jul 19, 2011
SOURCE: My Kettler cross trainer Mondeo
E-2 FAULTS ARE PROBABLY DUE TO A FAULTY CONNECTION BETWEEN THE CONNECTING PLUGS-MINE WAS,I CHANGED A LEAD IN THE END AND SOLVED THE PROBLEM.PLEASE SEE MY POST ON THIS SITE ON THIS MATTER. MARK DAVIES
Kettler UNIX PX Elliptical Cross Trainer. The rod to wheel is loose. How to tighten?
Question edited for clarity full 'make model (what it is)'.
Here is the manual with assembly instructions and the simple tools needed, 2 screwdrivers and a M8 spanner.
https://www.manualslib.com/manual/766855/Kettler-Unix-Px.html#manual
Kettler Ergometer XTR1 making squeaking noise when using it. It comes from front portion, tried all possible things but squeaking only increases
Kettler machines are known for it.
sometimes you can fix it this way. In the place where you use it, slacken off the frame fixing bolts, give the cross trainer a bit of a shake and then tighten all the bolts up again. The helps to put equal pressure on all the parts.
Video help as well.
Why does my kettler verso 309 crosstrainer automatically increase in difficulty until it is impossible to use
Maybe there is something interfering with the difficulty plus button it may be stuck. try holding the difficulty minus and see it that hold it level and if it increases when you release its a faulty button.
User manual for Kettler 07854-000 "Orion" Cross-Trainer Elliptal
Try here
http://toolbox.kettler.net/fileadmin/_kettler_dam_import/SPORT/Dokumente_-_Kataloge/Montage_und_Ersatzteile/Cro(ss)trainer/07854-_Orion_706f-1003.de,en,fr,nl.pdf
1helpful
2answers
My Kettler cross trainer Mondeo gives me program error E2 on the display. Kettler has cleverly hidden any information about what this actually means (so I can fix it). Thanks for any help you can...
10helpful
2answers
V-fit herculean cross trainer assembly instructions
assembly of the wires for v-fit herculean cross trainer
Top Kettler Exercise & Fitness Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
