Question about Acer Computers & Internet
Upgrade video card
What video cards can be installed to upgrade my computer?
  • 628 Answers
U check to check your motherboard, using what graphic port. Such as AGP or PCI-Express. Then only u can choose what model and brand of graphic card u want. U can choose either Nvidia Or Ati.
Posted on Jul 19, 2009
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
WHEN I TRY TO PLAY SIMS 3 GAME I GET A EROR MESSAGE YOUR VIDEO CARD DOES NOT SUPPORT SHADER MODEL 2 PLEASE UPGRADE YOUR CARD
a Video card (aka a Graphics card) is a physical component in your computer that renders images and graphics, the higher quality graphics card you have the higher quality of games and images you can play/render.
so what this error means is the graphics card that your computer currently has installed doesn't support a model of shader (think shadows) which is needed to run Sims 3 properly
you can upgrade these cards, but it all depends on other components of your computer as to which would be most suitable for you
if you know anyone with knowledge of computers consult them as it would be free, or otherwise you'll have to have a consultation with a computer technician at your local computer store
hope this helps.
Apr 14, 2011 | HP Pavilion F1703 17" LCD Monitor
What video card can i buy for my computer ? I have a HP Pavilion a1120n . It already has an internal video card , but i want to upgrade . Its a Intel (R) 82915G / GV / 910GL Express Chipset with 128 mb...
I suggest you install an AGP video card that suits your requirements. If you play games that require a powerful graphics card, then I recommend the G Force range of graphics cards. A computer shop can recommend to you a graphics card depending upon what programs you are running on your computer. The games programs usually recommends a graphic card with their games.
Don't forget to disable/turn off the on-board graphics card in the BIOS if you use an external graphics card.
Sep 20, 2010 | HP Pavilion a1120n (PX759AA) PC Desktop
Can i change the video card on a vaio VGN-NS240E? I have integrated video but would like to upgrade to something that can handle games. Anyone know how?
I'm sorry. It is not possible to upgrade the Inbuilt Video card. However, the Computer is shipped with the Express Card/54 slot. You can contact your nearest favorite dealer to get the Express Card slot supported Video card and install in the Computer. This improves the Graphic performance.
May 12, 2010 | Sony VAIO VGN-NS240E/W Notebook
Dell optiplex 210l mini-tower video card upgrade
Before upgrading a video card, it's strongly recommended to check the wattage specification of the power supply unit. If the installed power supply unit can cater the need of the newly installed video card then it can be used normally.
You may refer to the user manual of the Computer to check the wattage specification or the Power supply unit(PSU) or directly open the tower to check for the printed value on the PSU itself.
Oct 01, 2009 | ASUS Computers & Internet
EMachine Video Card upgrade
Ok so are you getting video from the card? Look in system information and see what graphics hardware the computers says is installed. Are you replacing a video card or did you add a card to the system? If you are adding a card make sure that you change the settings in the BIOS to boot first on AGP/PCI-E express slot. Make sure that fast write settings and bus speed settings are compatible with your card. For example if you purchased a 8X AGP card and your computer only does 4X the card may not work. Double check that you are trying to install the correct drivers for your card and operating system.
Sep 12, 2009 | E-Machines eMachines Desktop PC
Best video card upgrade for Gateway GT4024???? Stock computer....except ram upgrade to 2x1gb....want to increase the video handling from the slow onboard video
Your upgrade options for a better video card are really dependent on how much you want to spend.  You have a PCI express x16 slot which is what your are going to use.  Visit www.newegg.com and you can look up video cards by manufacturer, memory amount, and even filter it by how much you are willing to spend.  Here's a link at newegg for "the best video card upgrade":
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161203
Since there is a newer PCI 2.0 Express connection on newer computers, you can get your video cards cheaper now.  You will notice a huge improvement with any video card you choose since onboard video is about the worst.  Just remember to go into the device manager and disable onboard video card after you install the new video card.
Good Luck
Jun 10, 2009 | Gateway GT4024 PC Desktop
3D Video Card
what would the price range of the video card would you be looking for?
depending on the price range is depending on the card i would suggest.
Apr 07, 2008 | Computers & Internet
Computers & Internet Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
