Question about HP OfficeJet 7310 All-In-One InkJet Printer
When trying to copy, the printer just sits in the "warming up" mode and won't copy.
    President:
  • 3,085 Answers
You have a bad SCANNER ASSEMBLY. It's not worth repairing.
Posted on Jul 19, 2009
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
Hp photosmart premium wifi failure
@ Other computers might be beyond the range of wi fi limits, run the CD in other computers ask to detect.. if not detected suspect out range.Check obstructions of walls, beams, magnetic fields.
@ If printer is not scanning check whether copy happening or not, if copy is happening uninstall the drivers and reload it once again, if copy not happening check scanner unit warming up or not.
Nov 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Aug 29, 2011 | Kodak Cameras
How to put printer in print mode
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Aug 26, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
X4270 won't copy after replacing black cartridge. It did run an alignment page, however.
Try this approach:
  1. On the printer operator panel, on Copy mode, press Options.
  2. Select Maintenance.
  3. Select Clean Cartridges
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that Copying is properly functioning now.
Aug 08, 2011 | Lexmark X4270 All-In-One InkJet Printer
My Dell All-in-One 924 Printer stays in copy mode
hi  s_witt212  :
u can rest assure ., cause the default mode onthe printer is : mode -copy .
all dell ink jet printer model s have that as the default option .
the other modes are mode scan and mode fax .
u can choose any mode based on ur need .
hav a gooday !
Jul 25, 2009 | Dell 924 All-in-One InkJet Printer
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
When trying to copy a document the machine will go in the warming up mode and stay and will jnot copy.
turn off the printer and let it set about 5 minutes and turn back on. It will print after you do this.
Jul 08, 2009 | HP PSC 950 All-In-One InkJet Printer
Will not scan, goes into warm up mode and then turn power off and
Might try unplugging the power cord and letting it sit for about 20 minutes. Right off hand it sounds like its getting to hot. Even if it is turned off power is still going to the printer so it can still get hot.
Feb 10, 2009 | HP OfficeJet r40 InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
