Question about HP PSC 1315 All-In-One InkJet Printer
Scan a document
I cannot scan a document
  • 164 Answers
Install TWAIN drivers
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Posted on Jul 26, 2009
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
How do I scan into a PDF with MX922
Making an adjust to the IJ Scan Utility settings should fix this problem. Follow these steps:
  1. Open the IJ Scan Utility.
  2. Click the Settings... button in the bottom right of the window.
  3. Highlight Document Scan, to view the document scan settings.
  4. In the Save Settings section, change the Data Format to PDF (Multiple Pages) and click OK
  5. Back at the IJ Scan Utility window, load your documents in the ADF and click the Document button to start your scan.
Feb 19, 2015 | Canon Office Equipment & Supplies
I AM NOT ABLE TO SCAN DIRECTLY TO PDF FROM MY HP 4255 ALL IN ONE PRINTER
Scan directly using Adobe software from computer
  • 1 Position the first page of your document on the flatbed scanner and close the lid.
  • 2 In Adobe Acrobat, under the File menu, choose "Create PDF", then "From Scanner" and then "Custom Scan."
  • 3 In the Scan dialog box, choose your configuration settings. This will vary based on the nature of the document you wish to scan (e.g. color or black & white, images or text).
  • 4 Click "Scan."
  • 5 When the scanning process is complete, Acrobat will ask you if you wish to scan more pages into the file. If you do, position the next page on the flatbed scanner and click "Scan More Pages." Otherwise, click "Scan Is Complete."
  • 6 Repeat the above steps as necessary to scan a multi-page document.
    Read more: How to Scan a Document into a PDF ' eHow.com http://www.ehow.com/how_4895483_scan-document-pdf.html#ixzz18vbeLoUI
  • Dec 23, 2010 | HP OfficeJet 4255 All-In-One InkJet...
    How do i scan a document?
    Hi, it all depends on the printer your using.
    How to Scan a Document on a Multi-Function Printer
    A multi-function printer with a scanner makes backing up your important documents easy. The scanner function of the printer allows you to translate a paper document like a receipt or title deed into an electronic copy that is stored on your computer. Once you have an electronic copy of your document, you can process and manipulate the document as you would any other electronic file. Follow these steps to scan a document on a multi-function printer:
    Connect your multi-function printer and computer. Power them up.
    Select the side of the document you are going to scan. Give the document a once-over, checking for any flaws that you do not want transferred into electronic form.
    Open the printer's lid. Place the side of the document you want scanned face-down on the glass plate of your multi-function printer's scanning bed. Align the document to your satisfaction.
    Close the printer's lid carefully. You may want to weigh the document down with another sheet of paper to prevent it from shifting.
    Choose an appropriate scan resolution. You may have to do this using the controls of your printer or on the computer, depending on the model and software.
    Press the scan button to start the process. This can be done on the printer itself or on the computer.
    Preview the scan on your computer monitor. You should be able to make minor changes to the scanned image if needed.
    Save the scanned image if you are satisfied with the result. Try again if you are not satisfied.
    Tips & Warnings
    Scanning documents at high resolution and low data compression will produce the best image quality at the cost of file size.
    Not happy with a scan? Re-check the alignment of the document and try it again. Discard the duds when you get a scan that works for you.
    Using harsh cleaning chemicals such as acetone or benzene can damage your multi-function printer. Abrasive cleaners are also not good on the machine, particularly the glass surface of the scanning bed.
    ....How to Scan a Document on an All-in-One Printer?
    Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
    Turn on your all-in-one printer and computer. Check the connections between the two machines.
    Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
    Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
    Close the printer's document lid slowly so the document does not shift position.
    Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
    Push the scan button. You may have to do this on the printer itself or on your computer.
    Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
    Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
    Accept the scan and save. Return the original document to a safe location.
    Hope it helps..
    Oct 28, 2010 | Office Equipment & Supplies
    HOW DO YOU SCAN DOCUMENTS
    1. Position the document on your scanner.
    2. On the File menu, click Scan New Document.
    3. In the Scan New Document dialog box, select the options you want.
      • To select additional scanning options, click Preset options, and then click either Create new preset or Edit selected preset.
      • If you want to scan a double-sided page, select the Original is double sided check box.
    4. Click Scan.If you selected the Original is double sided check box, the Scan New Document dialog box reappears as necessary.
    5. If you selected the Original is double sided check box or the Prompt for additional pages check box, click Done to save the file after the last page is scanned.
    Note By default, OCR is performed automatically when you scan documents. To turn off this feature, click Scan New Document on the File menu, and then click eitherCreate new preset or Edit selected preset. On the Processing tab of the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned imagecheck box.
    Hope this helps!!!
    Please rate my response!!
    Jan 29, 2010 | Microsoft Word for PC
    I am trying to scan a document from HP 4280 All-in-One printer HP Solution Center to My Documents. However, I am unable to type Destination (My Documents) in the Scan to. I have reinstalled from the CD...
    Generally, the scan to field will designate the the type of program that you want to use to view/edit the document. An example would be microsoft word.
    Once you scan the document to a program, you can then save it in any folder on your hard drive, including "My documents". However, if you chose to leave the scan to on "Scan to a File", the scan will automatically go to c://useraccountname/My Documents/my scans.
    You can then go to my documents/my scans and move the scanned document to whatever location you would like on your hard drive.
    If you have any additional questions about this information, feel free to contact my by replying to this message.
    Thank You,
    Brian
    Jan 28, 2010 | HP Photosmart C4240 All-In-One InkJet...
    How do i scan multiple pages
    Please perform the steps given below to scan multiple pages to a single PDF file.
    NOTE: Before performing the steps please make sure that Adobe Reader is installed on your computer. If not installed then goto www.adobe.com and install Adobe Reader.
    1. Open HP Solution Center.
    2. Click on Settings.
    3. Click on Scan Settings.
    4. Click on Scan Preferences and Select the option 'Prompt for additional scans when preview is turned off'.
    5. Click on OK to apply changes.
    6. Now Click on Home and click on scan Document
    7. Select Document to File under scan shortcuts.
    8. Uncheck the option Preview Scan at right bottom of the scan window.
    9. Now Click on scan to scan document.
    10. When prompted for additional scan place the another document on scanner glass or ADF and Click on Scan.
    11. After scanning is complete Click on Finish to save the scanned document
    12. To Locate the scanned document (PDF) goto My Documents folder and Open My scans folder.
    Oct 12, 2009 | HP Officejet 6500 Wireless All-in-One...
    How to scan picture to upload on computer
    First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
    Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
    To scan a single document, place the document:
    1. Place the document face down on the platen glass.
    2. Open the MP Navigator 2.2 software.
    3. Click Scan Photo/Document.
    4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
    • Color Document(Simplex): Select this to scan one side of color documents.
    • Color Document(Duplex): Select this to scan both sides of color documents.
    • B/W Document(Simplex): Select this to scan one side of monochrome documents.
    • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    • Text(Simplex): Select this to scan one side of text documents.
    • Text(Duplex): Select this to scan both sides of text documents.
    5. Click 'Specify' and set the preferences as required. Click here for detailed information
    6. After making the setting changes, click 'Scan'
    7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
    The directions for Batch Scanning, or using the ADF to scan, are shown below.
    1. Place the document(s) in the Automatic Document Feeder (ADF).
      1. To scan using the ADF, remove any documents from the platen glass.
      2. Open the document tray.
      3. Insert the documents face-up in the ADF and then adjust the document guides.
        Note:
        When scanning using the ADF, the documents will automatically feed.
    2. On the Windows desktop, double-click 'MP Navigator 2.2'.
      1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
      2. Then click 'MP Navigator 2.2'. MP Navigator opens.
    3. Click 'Batch Scanning'.
      * Color Document(Simplex): Select this to scan one side of color documents.
      * Color Document(Duplex): Select this to scan both sides of color documents.
      * B/W Document(Simplex): Select this to scan one side of monochrome documents.
      * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
      * Text(Simplex): Select this to scan one side of text documents.
      * Text(Duplex): Select this to scan both sides of text documents.
    5. Click 'Specify' and set the preferences as required. Click here for detailed information.
    6. After making the setting changes, click 'Scan'.
      1. After the documents are scanned, a dialog box will appear indicating to load the next document.
      2. After the next document is loaded, click 'Scan'.
      3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
    7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
    8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
      Save to PC dialog box
      Save as PDF file dialog box
    9. Make settings to save a file. (Click File save settings for details.)
    10. Click 'Save' after all settings have been selected.
    Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Can't Scan documents
    on the scan options , "select "scan to pdf", it will scan as a document instead of printing.
    May 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Cannot edit scanned document
    its like this, the OCR or the SOftware installed in your computer is limited. If you're trying to scan a document which has a picture or with text that uses different fonts like monotype, or those that are not usually being use for normal documents, usually it wouldnt detect and it become distorted. Anyways, here are the steps that i want you to follow.
    1. Open solution center. (click start, go to all programs, go to HP, then click on SOLUTION CENTER). or you can see SOlution Center on your Desktop.
    2. Click on Scan Documents, then the Scan documents setting will open. Change the settings to these.
    * SCAN TO: Microsoft Word.
    3. Then, hit scan.
    4. After scanning, the folder My Scans will open automatically, just go ahead and open the scanned document.
    5. From there, you can start editing the text.
    ..remember, the scan a document is limited, it will not read all types of fonts. if the document is using a "times new roman" or "arial" the scanned document appears to be almost the same with the original. But, if the scanned document contains pictures or stylish fonts, that would make the document distorted.
    Please let me know if you still have clarifications.
    Thank you.
    adonscott
    May 01, 2008 | HP Officejet 5610 All-In-One InkJet...
    HP PSC 1315 All-In-One InkJet Printer Logo
    227 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
