Question about LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB
My LaCie 1T Big Disk Extreme just keeps clicking....
And my Mac no longer recognizes it. It is only 2 years old. I have checked all the wires and powered down everything. I notice you tell a lot of people to just go get the data off of it and I guess throw it away. I guess i shouldn't buy another La Cie.
  • 3,866 Answers
No do not throw it away buy another enclosure for it and take the driveout and put it into another enclosure you will have better results and a longer lasting drive and you be glad you did!
Posted on Jul 19, 2009
Error 252 lacie disk
Is your drive Old , and has been travelling a lot, could have been hampered, or the connecting cable corrupted, try another cable, or keeping hardrive in various different positions and working e.g upside down, sideways, If it does not work, you need a new one, back up whatever data you can.
Dec 10, 2013 | LaCie Big Disk Extreme with Triple...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
My lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Hear disk spinning in hard drive but my mac won't recognize the drive
This is probaly file errors on the disk that have generated over time. The problem is that your mac software wont load up the drive unless it is formatted or accessed in DOS. There are some freeware programes which you can download which recover hard drive from DOS (spinrite etc). If you cant access this in DOS with the software then the hard drive is trash.
The main problem of all this is that this is almost symptoms of a hard drive faliure or future faliure. If you get the info off your drive back it up defrag and format the drive every year.
Bear in mind Hard drives only have a lifespan of 1-3 years. In addition try not to fill them over 60% as your drive will last a lot longer.
hope you can rescue your drive.
Jul 28, 2009 | LaCie Big Disk Extreme with Triple...
Pc not recognizing drive when turned on
Maybe this can help you:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Have you tried the disk on a different system?
Jules
Apr 02, 2009 | LaCie Big Disk Extreme with Triple...
Trouble seeing my lacie drive possible mounting issue
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Aug 13, 2008 | LaCie Big Disk Extreme with Triple...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Help with big extreme disk partition access.
Don't know what operating system your using but in Windows 7 and up it's easy to partition any drive even while windows is running.
Go to --> Control Panel\Administrative Tools\Computer Management\Disk Management and right click - set the size.
You can change it any time as long as whats in it isn't bigger than the size you want to make it. I have a 1 TB in this computer and that's how I did it after discovering that my old drive tools didn't work on this.
For any info on this procedure (or darn near anything you can think off) you can always go to youtube for step by step instructions.
Just watch a few first because some people are better teachers than others.
Mar 13, 2017 | LaCie Bigger Disk Extreme 2000 GB Hard...
LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB Logo
812 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
