Miele Blue Moon Bagged Canister Vacuum Logo
Posted on Jul 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get a stuck bottle cap out of a vacum hose
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Jul 19, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801917
Points
33142
Hi there. You will need to slide something into the hose and force the bottle cap out. You can use something like a garden hose if it will fit, or a dowel or a piece of metal rod. If you don't have anything like that go to a home depot and find something that will work.
1helpful
2answers
My SEBO Pet vacuum makes a “screaming” sound when I take the main attachment off of the hose. It is absolutely fine when the long attachment is on and I’m vacuuming the floor for example, but if I use the...
Remove the hose from the bag housing by pinching the retaining ring that attaches the hose to the machine. Turn the vacuum on with the hose removed. If the sound persists, the sound is coming from the hose itself. Hold the hose, letting it hang towards the ground. Look through the hose to see if anything is lodged. A scream or whistle can be caused by a paperclip, bobby pin, toothpick, or paper fragment stuck in the hose. You could also have a small tear or hole in the hose material, so carefully inspect the hose for cracks or holes.
1helpful
Unclog vacum hose
Disconnect the hose from the canister and connect it to the blower end of the canister and this should blow out the debris or rag stuck in the hose.
Bottle cap stuck in vacuum cleaner hose
1) try to use WD-40 for loose the bottle cap, wait from 15 minutes and proceed to loose.
2) you can use pliers for help to loose this bottle cap stuck.
God bless you
Wont discharge shampoo!
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
1helpful
WATER WILL NOT COME OUT
My bissell wont release water or cleaner
My bissell isnt putting down any solution or water
My bissel proheat is not releasing the soap when the trigger is pulled
Try these suggestions to get your machine working properly:
5helpful
It wont spray the water on the floor.what do i do
I have Bissell 7920. The water is not being
Top Miele Vacuums Experts
john h
Ngoro
jws1013
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
