Question about Sony Cybershot S650 Digital Camera
Deleting photos on a Sony Cypbershot 7.2 megapixel
Is there a way to delete multiple photos at one time instead of deleting them one at a time.
Re: Deleting photos on a Sony Cypbershot 7.2 megapixel
As a matter of fact there is....
1).press photo replay button
2).hit the ''W'' button, it has somewhat of a checker board above it
3).press middle button, then hit select, green box will show
4).click middle button on all pics u want deleted
5).then simply trash it
hope this helps
if u need more info email me at:
Posted on Dec 01, 2007
0 characters
3 Points
How to delete multiple photos
You did not say which model Coolpix camera you have (there have been 168 models over the years) so I can only give you general information on deleting multiple photos; i.e., deleting all pictures in the memory.
On some models there are two buttons, usually the trash and one other button, labeled with a red dot. Depressing both buttons at the same time for a few seconds will erase everything. If your camera does not have that feature, the other method is to use the "delete all" menu function. Enter your camera's menus and scroll through them. You should find that function in the menus.
I strongly suggest that you follow the link at the bottom of this posting and download the manual for whichever model Coolpix you own for free. The Nikon's manuals all cover the process.
Nikon Product Manuals available for download Nikon Knowledgebase
Aug 07, 2014 | Nikon COOLPIX Digital Cameras
Sony DSC-W320 says "no space on memory card" even though it's completely empty
The problem most likely is caused because you are deleting EVERYTHING. Next time, instead of deleting everything, format the card in the camera instead.
May 13, 2012 | Sony Cyber-shot DSC-W50 Digital Camera
How do you delete multiple images from camera?
Are the pictures on a memory card? In that case, you're much better off formatting the card. If you continue to delete unwanted pictures, you'll fragment the card and ultimately you'll have problems. Every day somebody posts here with that problem. Formatting cleans things up.
If the pictures are in internal memory, select Internal Memory Tool from the Setup menu, and you can format the internal memory, deleting all the pictures. My earlier comments hold true here as well.
If you insist on keeping some pictures and deleting others, then go into the index (thumbnail) mode. Press the trashcan button, then select [Select] with up/down, then press *. Select images with the arrows, then press * to display the delete indicator on the selected pictures, Press the trashcan, select [OK], then press *.
May 13, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Fuji S1500 unable to delete photos after taking them. Unable to see photos back. I delete photos on my loptop and then they appear again.
Deleting or formatting on the computer instead of the camera corrupts the card. The camera does not recognize the operating system used to delete. Stop using the computer to do that!
Apr 12, 2010 | Fuji FinePix 3800 Digital Camera
After I transfer my photos to my computor I delete them on my Sony digital.i take more photos when i transfer the new ones to my computor all the old ones that I had deleted are still there.Why?
I cannot explain why, but i can suggest a different way to go about this so you don't have the problem anymore.
Try formatting the card instead of just deleting the files.
I know on a computer when you delete files from the hard drive, the files are still there, the computer only removes the index to the information, but the data remains there. This is the same thing that could be happening on your card.
Nothing beats a failure but a try, try formatting the card next time and see if that resolves the problem.
Thanks, and if this helps please rate my answer.
Mar 06, 2009 | Sony Digital Cameras
Nikon Coolpix L14....deleting multiple photos
If you are looking to delete them all at once on the camera, you can format the card.
But really, the best way to manage pictures on your camera card is to use a card reader with your computer/laptop to delete/copy pictures from your camera card to your computer/laptop.
Jan 28, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Idk how to delete!
You can download the manual for your camera here:
To delete photos:
  • Enter the playback mode.
  • Press the [Menu] button
  • Use the up/down buttons to select the trashcan (delete) icon.
  • You can use the left/right buttons to select single image, multiple images or All images.
  • Press the center (round) button.
  • Press the center button (repeatedly if doing multiple images) and then Press the [Menu] button again and choose OK.
That should do it.
Note that you can also delete photos quite easily by connecting the camera to your computer with the USB cable and deleting the images with Windows Explorer.
Jan 02, 2009 | Sony Cyber-shot® DSC-W120 Digital Camera
How can i erase all the photos at one time.
there should be a format option somewhere
delets all pictures and fixes that delete problem
Dec 21, 2008 | Sony Cyber-shot 10.1-Megapixel Digital...
Deleting all photos at once
page 29,
delete all,.......{clip} from index mode, select folder and delete
Jul 03, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cybershot S650 Digital Camera Logo
100 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
