Question about Dryers
Motor won't run - Dryers
    President:
  • 1,922 Answers
Either you are missing one leg of your 240 volt feed(chk receptacle) or on a capacitor start motor the cap is weak,if you have 240volts open dryer door and spin drum by hand and have someone push dryer start button at same time you spin drum the cap is just in circuir to start dryer mtr(be careful diong this)hope it helps(otherwise
Posted on Jul 29, 2009
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Blower motor won't run
Check for voltage at blower motor connector. If battery voltage is present....remove and replace blower motor.
Nov 26, 2012 | 1994 Ford Taurus
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Our Razor MX500 won't run with out giving the motor a little help getting going. We took the motor off and hooked it to a battery charger and it works fine, you put it back on the bike and it won&
remember the motor transfer the power to the front..there no weight on the motor when you take it off..the motor can be going bad/a singnal! most people change the battery without checking the motor for wear..
Sep 14, 2012 | Razor MX500 Dirt Rocket
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
Fuse in motor keep blowing and motor keeps running but once stopped won't restart
What year, make model and engine size there? Send details please.
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
1996 buick riviera heater blower won't run. I jumped the motor and it runs. Turn on the switch and it won't run
you have a piece of solder broken off the controller of your hvac unit, causing power not to get to the blower motor it self. take test light and see if you have power at the blower motor. check and see if you have continuty or brake between the power wire at the blower motor and at the hvac control unit. if wires are good then the problem will lie in the hvac control unit. check and see if the blower is working at all speeds, if it works on some speeds thens the blower motor resistor.
Sep 29, 2011 | 1996 Buick Riviera
My Robo Kleen motor runs but the wheels won't turn
if motor that runs is it the pump ? is drive motor running check belts or drive system inside
Aug 22, 2011 | Smartpool Dolphin Robo - Kleen Above...
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
Dryers Logo
57 people viewed this question
Top Dryers Experts
