My unit would only come on for a few seconds, then shut off, bought another unit with a damaged LCD, screen, but otherwise the same unit,replaced both boards, now the screen stay on, but is stuck in the test pattern, I did push the button on the video board, is this what started the mode it's in? can I and how get out of this mode? I have a little knowledge on TV repairs but need your help, Thanks, Rick
  • tickyricky_7 Jul 19, 2009
    It's an VIZIO model #vw42l-hdv tv10a
    do I wait for you on your site,
    President:
  • 2,777 Answers
Whats the actual make and model TV, do you have the part number of the board(s) as well?
Thanks
Tim
Posted on Jul 19, 2009
  • Tim Grayson
    Tim Grayson Jul 19, 2009
    You don't have to wait here, you will get emails, let me research this.
I recently fell on my blackberry curve 9300 3g and the screens has now turned white, hod do i resolve this problem?
Switch off the phone, remove the battery for few seconds then refit it. Now start the phone. If it works fine then ok otherwise the LCD seems to be damaged which can be replaced at auth. Blackberry service station, contact them.
May 11, 2011 | Cell Phones
I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Jun 03, 2010 | Dell SE198WFP LCD Monitor
My HannsG 28" (HG281D) shuts off the screen intermittently, as if it were overheating and was self-protecting. Power light remains on and steady. I can turn it off and wait a few seconds, when I turn it on...
That happens when the ballast transformer for the backlight overheat. Backlight or cold cathode light function is responsible for the images that you see in the screen.
Unless you are capable of replacing by yourself the parts with the same value and you have the right tools and skill to do it your own.
Otherwise, I suggest you bring your monitor to a credible technician.. or if the unit is still under warranty you can bring that to their service center..
May 20, 2010 | Hannspree HannsG HG281DP 28" LCD Monitor
Monitor turns on for less than a second, then off. I bought a 19" Samsung LCD monitor (953BW) about 10 months ago and the first time I used it, it would only switch on for a split second and shut down. ...
Although the OP was 2009. I had this problem.
I simply replaced the power board. Which I bought from ebay for $20AUD.
It was real easy to remove as well. Just have a look for youtube videos.
Fixed!
Aug 31, 2009 | Samsung 953BW LCD Monitor
Unit comes on but goes off in a few seconds. Sometimes shows the "critically low battery" screen but not all of the time.
most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
May 27, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
The LCD of my Nokia 5310 is amaged, can I fix this?
It sounds like the LCD screen is going out. If you are still under warranty, try to get it replaced.
If not, you can buy a replacement 5310 LCD and replace it yourself.
A new 5310 display costs about 20 dollars from ebay.
I wrote a detailed guide to help you put in the new Nokia 5310 LCD screen.
Check it out at the following link for the guide and links to buy the LCD
Nokia 5310 LCD Screen Replacement
Hope that helps
Feb 22, 2009 | Nokia 5310 Cellular Phone
My Benq screen shuts down 10 seconds after switchung on
it may be overheat or check the cables it will properly connect or not(may be loose connection or damaged).
click this link for more info
Feb 22, 2009 | BenQ FP731 17" LCD Monitor
Nuvi 205w LCD screen replacement needed.
Your only reasonable solutions are:
1) Send it back to Garmin for repair, which will probably cost you more than the unit is worth, or...
2) Check CraigsList or other places for good deals. The prices on these things have been in nose-dive mode for months and you're liable to find a very good deal for very little money. (I just bought a StreetPilot C330 for $50 from CraigsList last week.)
Jan 16, 2009 | Garmin nuvi 205W GPS Receiver
Samsung lcd tv
the problem is the internal power supply module has gone bad the first sign is usually the pip if included stops working... well open your lcd monitor try not to damage screen for those who have carpet you may want to use glove to keep your self grounded from cause any other damage to components the boards are usually sperate unit in the new models unplug the powersupply unit
(you can tell because the outlet that the cord connects to will be locate on this board)
once remove locate part number and call manufacture to order part another method to by pass manufacture take unit to your local tv shop it has to be a good one because most only buy new parts but ask them to test and replace bad part of power supply should be faster then manufacture send replacement part
no manufacturer want you to fix they want you to buy new units again
Jun 12, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
