Wondering why I can only get the low speed. Whe I try upping the speed the spa shuts down.
SOURCE: Pump will not work in high speed
Clean the relay contacts on the board. Cut the power, ofcourse. Also, try switching the hot wire on the low side of the pump to the high side to rule out the pump.
SOURCE: I have power to the spa, but it won't power up
there are at least two separate circuit breakers feeding your spa and two reset buttons. the circuit breakers are located a few feet away from the spa in an electrical box.
the reset buttons are in the mechanical space of the spa where the pump and heater are located.
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
SOURCE: My balboa spa just keeps running constantly and
It may be in sleep mode or Eco mode. If you hit jets then lights it toggles through. You need to be on st mode. Which is standard
