Question about Hoover PE235 Front Load Washer
Timer just spins round
Hi when we start the wash, sometimes the timer just clicks round without completing any of the cycles. Sometimes it even clicks round to a different wash cycle. (ie we've had it click from non/fast colours to 90c white wash). Any ideas? I'm about to order a new timer but thought i would check first.
    Problem Solver:
  • 9 Answers
yes it is the timer,i had the same thing happened to me on a hoover,i was told that the fault was when you turn the timer to a programme to do this slowly and gently and if you go pass a programme not to turn it back but to go forward again until you get to the right programme..hope this helps.all the best..ps a new timer may cost about £80 to £100.
Posted on Nov 23, 2007
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
GE washer won't complete cycle
there are contacts inside timer which may not be working properly. in any case they are not repairable.
Oct 28, 2009 | GE Washing Machines
My series 90 washing machine stops midway through the rinse cycle
Hi, faulty timer motor or timer, knob you turn for different cycles (programs) , it's called timer, that timer usually run by small motor, and sometimes burnt out, could be electronic too, remove top back panel, look at timer, you'll see small motor, attached by two small screws, remove motor, place ohm tester lead, and check for continuity. if motor is burnt out, replace it, if your timer is electronic, you will have to replace complete timer, good luck.
Aug 08, 2009 | Kenmore 22422 Top Load Washer
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Sometimes the spin cycle works and sometimes it doesn't. The water is draining, but sometimes the clothes are still very wet and I have to wring water out of them before I put them in the dryer.
if that is a top load whirpool suspect transmission..the transmission is designed to drain first and then after another timer pause go into spin sometimes after the pause they fail to do so it is a hard problem to verify without a lot of patience..put washer into final rinse allow washer to complete cycle on it's own DO NOT MANUALLY ADVANCE TIMER OR OPEN LID if possible you can raise lid and hold lid switch down.. after agitation there should a short pause then pump out then another pause and spin should engage if you do not here spin raise lid then shut if spin starts change transmission..on rare ocassion have seen timer never pause then change timer if this is only occasional may be hard to spot and may require more than 1 attempt to catch it..good luck
Sep 07, 2008 | Washing Machines
Have maytag washing machine model no LAT5006AGE serial no 25000887yk which will not spin belt appears ok but motor is not working for the spin cycle. It washes fills drains all ok do you have a solution...
Possibly a lid switch. The washer shouldn't spin if it thinks the lid is open. Possibly a wiring issue. Check the wiring to the motor. If those check out it could be a problem with the timer. Sometimes bad contacts in a timer can be checked by turning the washer on in the spin cycle where it should be working and wiggling the timer shaft up and down and around without turning the knob. If the washer starts and stops, you've got a bad timer.
Jul 20, 2008 | Maytag Washing Machines
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Hoover H120M Washing Machine No fabric softner and dial clicking round
always check your carbon brushes which are situated at your motor covered in a plastic covering must be at least 8ml long these start at 1inch in length may not be giving enough contact to your motor for the timer to click into action m8 but if these are ok then it will be more than likely your timer which is faulty with it not doing the water inlet valves properly
Nov 03, 2006 | Hoover H120M Front Load Washer / Dryer
Hoover PE235 Front Load Washer Logo
300 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
