Question about HP Office Equipment & Supplies
Last print line of any doc printed with HP J6480 is cut off
I have a HP J6480 All-in-one printer. Any time I print a document, the last line is cut-off (i.e. the top half of the line prints, but the bottom half of the line does not print). This situation occurs regardless of how close the last line is to the bottom of the page.
  • Anonymous Mar 12, 2014
    HP P2050
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Posted on Aug 17, 2009
HP OFFICE JET J6480 ALWAYS SPEWS OUT EXTRA BLANK PAGE AFTER PRINTING
Check if your document has empty lines at the end. Use your keyboard down arrow to scroll past the last line of text. Then backspace until you get to the last line.
Mar 09, 2016 | HP OfficeJet Office Equipment & Supplies
HP 6500 cuts off last line. Help
got to control panel and click on printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jan 11, 2010 | HP Officejet 6500 Wireless All-in-One...
The last line of every document is cut off and the bottom half is missing as though the margin isn't long enough, but that's not the case.
Try to print a self test page using the below steps
  1. Load U.S. Letter, A4, or legal size paper into the input tray.
  2. Press the Setup button.
  3. Press 1 to select Print Report , and then press 1 to select Self-Test Report .
  4. Press OK . The self-test page prints.If this prints fine, perform the partial reset of the printer using the below steps:
    1. Unplug the power cord from the HP All-in-One.
    2. Wait for 20 seconds.
    3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
    4. Release the buttons after the HP All-in-One starts up.
    5. The HP All-in-One will now be reset to factory defaults.
Sep 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
NOT PRINTING LAST LINE ON PAGE
it could be that the lines on the spreadsheet arent bolded correctly or the spacing at the end of the document needs to be shortened. try to delete one space so that that line is brought up a line.
May 27, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I keep getting a test page before printing my doc or picture
To resolve test page prints every time issue, perform the steps provided in the below webpage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065136&cc=us&lc=en&dlc=en
Now, perform the steps below to change the settings from last to first page:
===== From the HP Solution Center software =====
1. Open the HP Solution center.
2. Click Settings--Print Settings --> Printer Settings
3. Click Advanced Tab.
4. Under layout option select the page order from "front to back".
5. Click OK and try printing.
From application
a) Select tools
b) Goto Options
In that select print tab
c) Check the Reverse Print order option.
d) Click Ok.
Apr 17, 2009 | HP DeskJet F380 All-In-One Printer
New Vista Computer wont print last line, XP no problem
Using the print or printer setup (I can remember what is actually written) from within word. ensure that the print margins are not to small and cutting off your words, or if the print is appearing close to the edge of the paper when you print, you maybe outside the range of the prints ability to print that close to the edge of the page in whice case you would increase your margins in the print setup (ie from .125 to .375 or .50)
Apr 03, 2009 | Computers & Internet
Bottom of page is cut off sometimes printing from vista computer
I had same problem with Vista machine and hp c309 printer cutting off 1/2 of last line. Tried all other listed fixes and none of them worked. Eventually I found a fix that worked for me though.
1. Go to the control panel and select the printer
2. Right click and select Properties
3. Go to the Ports tab
4. Uncheck 'Bidirectional Support'
5. Click apply.
Hope this helps! It worked for me.
Jul 08, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Last page of some docs won't print
Within the driver you can select what graphical language to use try a different one and see if that helps also check the paper size settings
hope this helps and please rate me
Cheers J
Aug 29, 2007 | HP LaserJet 1100 Printer
1,058 people viewed this question
Seeker5211
Seeker5211
