Question about Cameras
Olympus SP-310 Problem
I am having problems with my SP-310 Olympus Camera. When I power up the camera the amber and green led lights flicker and a "Battery Empty" error immediately appears in the LCD even with fresh batteries installed. Sometimes the lens will extend but most times it does not. No camera functions are available ie. picture taking/picture review/menu access etc. After a short time the camera beeps and shuts down. I have sent the Camera to Olympus for repair and they have supposedly done a "Firmware Upgrade" but when it was returned I am still having the same problems so I am reluctant to resend it for repair again. Any ideas as to what the problem may be
Thanks Lou
  • 2 more comments
  • stukely Nov 19, 2007
    Front view
    I tried that it does not work
    I would appreciate additional assistance
    Being a non techie what exactly does a "Firmware upgrade" do? and given the fact that olympus repair supposedly carried out this upgrade the first time. Would this have anything to do with the continuing problem? I am somewhat reluctant to send it back for repair until I have an inkling of what may be causing the problem
    Genius:
  • 2,985 Answers
This problem may not be a firmware problem at all but a major board fault.
Either way the repairer fail to repair#
So they must repair it or replace it no argument.
Posted on Nov 21, 2007
  • 328 Answers
You should take it back for repair because this one should be free for you since they did nothing the first time.A firmware upgrade is easy to do yourself too. I hope they fix it this time.
Posted on Nov 19, 2007
  • Lyle Siemens
    Lyle Siemens Nov 19, 2007
    By going onto the Olympus website, you should find a place to upgrade the firmaware which is a little program update. It should not cause any problems but possible. If the camera had the problem before the upgrade, then it is not the problem. These upgrades are done with the camera attached to the computer and running a little program. It seems obvious that the repair people never even bothered to test your camera after. They should do the repair for free. You have to tell them how disappointed you are in the last repair. I wish I could look at it for you. If your not confident with the last place, you should look for another but I am trying to save you money.
    Sergeant:
    Champion:
  • 298 Answers
You might try adjusting the battery terminals
if it has springs pull them up a little clean the
contacts. tape & cushion the batteries down so they
dont move around. this has worked before for me in
situations as you describe it worth a try.
  • Eugene Merritt Nov 21, 2007
    I had a similar problem with a
    camera it would only take pics
    with the usb cable connected &
    batteries removed using the
    software bundled with the camera
    had an option to use as still cam
    or video cam (web cam)
How do you delete images on the Olympus sp 310
The delete button is above the LCD monitor on the back of the camera, the second button from the right, marked with a trashcan. While viewing the picture you want to delete, press this button. The camera will prompt to make sure you want to delete the picture.
Apr 19, 2012 | Olympus SP-310 Digital Camera
My olympus sp-310 camera shows empty battery but I have a new charged batterys in it
Are you sure you put them in with the correct polarity facing the right way. Its a common mistake.
Also try a "known" set of batteries just to make sure.
Good luck
Nov 04, 2009 | Olympus SP-310 Digital Camera
Dropped Olympus SP-310 in water for 2 seconds. After drying out everything works except for a dark LCD when attempting to take a picture. Focus green light flashes and shutter will work, but no picture is...
If your device gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Sep 14, 2009 | Olympus SP-310 Digital Camera
Olympus - SP-310 camera. Has broken LCD screen.
I Have a sp310 camera... It has a problem with optical zoom. Do you like to sell me your camera ou can you buy my camera?
Sep 07, 2009 | Olympus SP-310 Digital Camera
My Olympus SP-310 has wavy lines in all the pictures. I found a solution before on the internet - it recommended changing one of the settings. However, I can't remember what it was, and I can't find t
If the camera was working fine "before" you made a setting change, try going into the setting and selecting "factory Default" That may correct the setting you may have experimented with. And, make sure your battery is fully charged first!
May 25, 2009 | Olympus SP-310 Digital Camera
Zoom error olympus sp-310
no the memory card is not the problem .... the internal gears or blocks which intialises the lens may have been dislocated due to which this problem is occuring ,..... it has to be fixed from a repairman ,....
Dec 07, 2008 | Olympus Stylus 700 / 700 Digital Camera
Zoom Error
Have you tried changing the batteries to new/charged ones?
Jul 21, 2008 | Olympus SP-310 Digital Camera
Problems with camera
Hi everyone,
I found you because 10 minutes ago, my camera exhibited the same behavior as all yours. All of a sudden, the red and green lights started blinking on and off and nothing worked. I just tried switching batteries and the camera is working! I am using a couple of RCR-V3 Li-ion rechargeable batteries, which I purchased on Ebay three months ago. Thought I'd pass it on.
Take care,
Rosane.
Jul 17, 2008 | Olympus SP-350 Digital Camera
Cameras Logo
87 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
