Question about Pelonis Heating & Cooling
Wont blow out cold air anymore? - Pelonis Heating & Cooling
  • 744 Answers
Hi...
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner...
hope this will give u a clear idea..
thank u
rate me!!!!
Posted on Jul 19, 2009
Hi. I need help fixing my urka-a042jk10e Air Conditioner please. It's not blowing any air up thru the vents and my house is 97 degrees!
Possible that the compressor is not running. Call a service tech. Could be a run capacitor bad, stuck reverse valve or even a shot compressor.
Jul 30, 2016 | Heating & Cooling
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Does the GE a/c asr05lcs1 take water
No you do not add water to A/C unit,its job is to remove moisture from the air,so make sure it is draining out the back ,if it wont blow cold after that get rid of it ac units are not to expensev anymore good luck
Jul 21, 2012 | GE ASR05LC Air Conditioner
Not blowing cold air anymore
Possibly dirty evaporator coil or condenser coil. Maybe dirty filters. Also could be low on refrigerant charge.
May 17, 2010 | GE AJCQ08ACB Air Conditioner
The air conditioning isn't blowing cold air anymore. It takes a while for it to get Cold, it blows cool air but not cold.
My name is Ron,and I have one solution,Sounds like you need some freon added,if that doesn`t fix ya ,the ac compressor could be weak,or blockage in ac system,or vent door not opening,or opening slowly,and not all the way...hope this helps,roniecon@gmail.com
Jul 19, 2009 | 1996 Ford Explorer
My a/c wont blow on high and the air is not cold
if it will not blow on high than, it is probably a bad blower resister! if air is not cold recharge system,
Mar 16, 2009 | 1994 Oldsmobile Cutlass Ciera
My heat doesnt work why ???
Hi i'm ryan, is it blowing cold air, or just won't come on at all? If its blowing cold air try checking the antifreeze level, low levels will cause it to blow cold air. If it is just not comming on at all, try checking the fuse for the heater.
Dec 21, 2008 | 2003 Jeep Liberty
I have a 1999 Dodge Ram 1500 the air blows out ice cold for about 20 min. and then just shuts off what would cause this I put a gauge in the vent and it was blowing out 38 degrees
I have a 1996 Dodge Ram 1500 club cab. I have had my a/c recharged but it is only blowing barely cold air. It used to shut down when I accelerated and blow hot air before. I don't have that problem anymore except barely cold air. Any solutions?
Jul 26, 2008 | 1996 Dodge Ram 1500 Club Cab
Doesn't blow hard anymore
First make sure unit is correct for the size of room. You may have to mount it permanently so that it's tilted so it drains out the window. Check freeon level.
Jul 15, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
750 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
