Question about Palm Treo 650 Handheld
Keeps resetting itself
My phone keeps resetting itself over and over. and it wont stop till my phone dies, but when i charge it, it does it all over again. ive tried resetting it but it wont work.
    Sniper:
  • 59 Answers
There is a small watch cell battery inside your phone cercuite. actually its not a lithum watch cell. replace using another phone watch cell.
Posted on Jul 19, 2009
My phone wont go to my lock screen it keeps turning on over and over again
Try removing the battery, wait 30 seconds, and replace the battery.
Nov 04, 2014 | Boost Mobile Kyocera Hydro Smartphone
Cannot turn on
from https://discussions.apple.com/thread/2462356?start=0&tstart=0
Try pressing SLEEP/WAKE button and HOME button *at the same time* to force it restart for 2 or 3 times and see if it can turn on. Sometime it's just turn off by itself (happens more frequently for me esp when the battery is low) and we have to force it to start again.
Hope this helps,
Jan 03, 2014 | Apple iPad 64 GB WiFi
More consuming battery every day i charged my galaxy s4
reset the phone to factory.
let the phone die.
charge the phone till 100%
when at 50 % charge again till 100%
let the phone die
Charge to 100%
Nov 28, 2013 | Samsung Cell Phones
Keeps restarting itself
Sadly, some batteries will wear-out within a certain amount of months, and some may go even greater lengths until they will require replacement. This is one thing many people may not know when they are charging their device: Devices that use internal rechargeable batteries also use extra memory to know the charge limit point. So if you charge your the battery the device must know when to stop so the battery wont over heat and be damaged. This memory used to charge your battery can also be confused and malfunction, so that the device wont get proper power supply from the battery. This malfunction will usually occur when you plug in your device and use it at the same time or if you charge your device at random moments instead of letting it get to it's lowest power point then charging it again. I suggest that you let the device die fully, then let it rest for a few days, then while you charge it, have it off instead of on, that way the charge wont interfere with the screen info and let it charge as long as it is said to take on the manual that came with the device. If this fails, try 2 more times,if no luck after, have the company change your battery, dont try to change it yourself if it's bulit in, because some batteries require soldering a similar technique to welding something together, you can do this your self if trained, but you may also void a warranty if you have one with the device. If you'd like anymore info on your device leave a message for us at Game-Shabang official on Facebook, thank you
Oct 25, 2013 | Audio Players & Recorders
2000 Mitsubishi montero sport limited keeps dying while driving
my monterosport 2001 runs great till you come to a stop sign the rpms drop and it dies start it back up revs itself and rpms drop and it dies. we can start it up rev it and it clearsup and idles but later on when you come to a stop it dies again we have cleaned the egr valave and still same thing could the tps be the problem or what?
Apr 24, 2012 | 2001 Mitsubishi Montero Sport 4WD
Hi One month back I bought sony xperia x10.It is worked fine till 2 days back.But now it is not charging.Battery stops charging at 87%.I kept over night for charging but still it stops at 87% or...
Hello and welcome to FixYa!
This may happen, don't worry. There may be different reasons behind this. First things first. Do this; Use your phone, and drain the battery to 0%. The phone will switch off at 1 or 2% turn it back on and use it, it will again turn itself off, then again turn it on until no charge is left. After achieving this state, charge it as normal and see if it goes to 100%.
If again not, then put the battery out for an hour and put it back on then try to charge it to 100%.
If in case the problem is still there, then I'll recommend you to update your phones Firmware, to do this you need to have the USB data cable of your phone, if you have it kindly download this application, install it and follow the instructions.
NOTE: Make a backup of all your data and contacts before an update.
If after all this struggle you find yourself again back there, time to get a new battery or use it as much you can.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
May 10, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My upstage wont charge and keeps flashing on and off
Try reseting phone, if that doesn't work you will have to take it into sprint. This phone has alot of bugs.
Mike
May 10, 2009 | Samsung UpStage SPH-m620 Cellular Phone
My nokia n95 keeps turning itself off
my nokia n95 keeps turning of . every time i try to turn it on it turns on and keep restarting till the battery dies.. any solutin for it please.
Jul 05, 2008 | Cell Phones
Pearl 8100
let it charge till the light stop flashing
May 21, 2008 | RIM BlackBerry Pearl 8100
Palm Treo 650 Handheld Logo
376 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
