Question about Garmin GPSMAP 76 GPS Receiver
5yr old Garmin 76s shuts off
Unit starts up, aquires sats and performs all functions but consistantly "shuts off" ie screen is blank except for a verticle line about 3/4 in from the right screen margin....will not respond to on off switch, I pulled out the battery and it resets but only stays on 12-15 min then shuts off the same way again! Help
KUDOS! Others with the same problem informed me that it is a softwear problem and to download the 4.0 version free on the Garmin web site....l'll do it ASAP and write again if it doesn't work...RG
Posted on Jul 19, 2009
Garmin 76S handheld; power shuts off with a black vertical line on the screen.
When I have seen this problem in the past it generally means it is time for a new unit or a repair. It is a hardware issue that a user can not fix. For your local repair depot please contact Garmin @ 1-800-800-1020
Jul 13, 2010 | Garmin GPSMAP-76S Handheld GPS Receiver
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Just quits
I had the same problem (blank screen, vertical line). Per Garmin, turn off the WAAS function. Disable it for now, because the government has changed the WAAS signal coming from the satillite, and Garmin has not yet come out with a remedy to correct this problem yet. It should be out in a software update sometime in the future...............I did this and it corrected my problem immediately. The unit performs perfectly now, however, the accuracy is not as good, due to the lack of WAAS.......................
Dec 04, 2008 | Garmin MAP76 handheldS GPS Receiver
Screen goes blank except for a verticle streak
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Nov 03, 2008 | Garmin GPSMAP 76S GPS Receiver
Screen goes blank except for a black line
I had the same problem with my 76S. Called Garmin to send it back for service. They said it was a problem with new WAAS signals that causes the freeze/black line. Disabling WAAS using menu/system solved it for now. They are working on a software update Real Soon Now.
Oct 29, 2008 | Garmin GPS 76 GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
MAP 76 locks up in normal mode after acquiring and starting to track, three to four minutes. Screen goes blank except for vertical stripe, no keys work. Have to pull batteries to turn off. Unit works...
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. Just so you'll know, I also did a software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS.
What you said does make sense. When you have your unit in simulator mode, the GPS receiver is turned off, so it is not receiving signals from the satellites. The strange signal from the WAAS satellite must be what has been messing things up. Good Luck!
Sep 26, 2008 | Garmin GPS Map 76 GPS Receiver
I have a garmin GPS map 162 and during operation the screen goes blank except for a vertical line.None of the controls allow me to shut down, I must disconnect the power. I called Garmin and they sent a...
The problem is the government made changes to the WAAS satelites. When the GPS tries to find the sattelites, it can't lock on and goes into an error mode and locks up.To eliminate the problem disable the WAAS which can be done when starting the unit. Then go online and download the 3.70 firmware version and load it into your unit. This will correct the system to function with the newer WAAS system. After installing the 3.70 software then you can enable the WAAS function.
Good Luck
Richard
Sep 06, 2008 | Garmin GPS
Navigation screen freezes GPS unit
I believe they fixed this problem with a firmware upgrade. Use Garmin's web updater to perform the updates.
Jul 07, 2007 | Garmin eTrex Legend Cx GPS Receiver
Garmin GPSMAP 76 GPS Receiver Logo
509 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
