Question about Hoover F5906-900 Upright Steam Vacuum
My Hoover Carpet Cleaner is leaking out the bottom when I use the hand tool
  • 97 Answers
This could be the little white valve that the water comes out of, if its leaking from here or if its leaking at the bottom of the machine it could be the pump
Posted on Jul 19, 2009
  • 578 Answers
Suggest that you clean as much of the machine's insides as possible. Note that all of the clean water that remains in the black supply hose (you can see it when you remove the dirty water tank) will dribble out of the machine after it is turned off (this is normal - and I advise setting the machine on a towel for a few minutes after each use).
Posted on Nov 24, 2009
  • 1 more comment
  • Mary Smith
    Mary Smith Mar 12, 2014
    water runs out the bottom of machine when cleaning furniture
  • Mary Smith
    have only used machine 4 times sense i bought it 2 years ago
  • Mary Smith
    how to tell if its pump
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
How to clean suction area
If you are referring to the front nozzle area, Hoover has made a tool called a nozzle cleanout tool # 39514003
Sep 13, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Water leaking from bottom
Trun switch off
Unplug from wall
Remove all clip on parts, remove all covers as far as you can (screws)
clean all parts carefully
put back together ensuring the seals are clean.
Hope this helps a bit
good luck
Jul 13, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover SteamVac carpet cleaner leaks water
i have a hoover carpet cleaner and when it is not in motion it leaks water
May 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover steamvac turbopower 5000ls will not spray for hand tool
my turbo 5200 will not pick up the moister into container to dry does anyone know what the problem may be
Sep 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Solution for "hoover steam cleaner keeps
Hoover Carpet Shampooer
You might just need a new gasket. THey are inexpensive and fairly straight forward to replace with the right tools.
Sep 10, 2009 | Hoover F7431-900 SteamVac Vacuum
Model #5880-900 Hoover spin brush carpet cleaner
i WAS LOOKING AROUND FOR A SERVICE MANUAL FOR MY F5897900 CARPET CLEANER AND I SAW SOME THING ABOUT HAVING TO "PRIME" THE PUMP. YOU PPARENTLY TAKE THE TOOL HOSE AND HOLD YOUR HAND OVER IT FOR ABOUT 15 SECONDS. THIS MAY OR MAY NOT WORK.
ANYBODY KNOW WHERE I CAN FIND A SERVICE MANUAL FOR A HOOVER CARPET CLEANER? SEEMS TO BE A VERY CLOSELEY GUARDED SECRET.
RON
Sep 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Hoover F5906-900 Upright Steam Vacuum Logo
2,380 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
