Question about Simplicity for Children 8994W Crib
Lost manual for crib modell 8800w
Need instructions for toddler bed conversion..........with small side rails
SOURCE: Converting to toddler bed
simplicityforchildren.com has replacement parts
Posted on Nov 18, 2007
SOURCE: CONVERTING TO TODDLER BED
http://www.elfe.net/e/aboutelfe.asp?SectionID=43&s=0733HDD
Posted on Jun 08, 2008
SOURCE: converting crib into toddler bed
Call customer support @ 18002951980 and customer support can either email or fax instructions at no charge. I just did it and got the instructions myself. Or you can email me @ shannaboxley@yahoo.com and I'll foward the instructions to you.
Posted on Jun 20, 2008
SOURCE: Crib to toddler bed instructions
I need instructions to transform my mama and papas Aspen Cotbed into a bed! We have lost the instructions! Can u help?
Posted on Oct 17, 2008
SOURCE: simplicity crib instructions for model # 8745h
My granddaughter uses Ellis bed, similar ... I have scanned the manual.
Simplicity is no longer.
The manual can be downloaded @:
http://users.waymark.net/crude/Simplicity_Ellis_Manual.htm
Hope this helps
Crude - D10 Escapee 12-26-06
Posted on Dec 31, 2008
I have a vickie crib .I want to convert to toddler bed. If I take the front rail off there is'nt anything to hold the bed up in the front. It unscewss from the side. Help! Bed was purchaced 9/2008 ...
Is this a 4-in1 convertible crib? The Toddler bed will need the bottom railing and a half rail to convert from a crib to a toddler bed. The half rail can also be removed to make the 4th conversion to a toddler bed with out railing. But to convert this specific bed you DO have to add the bottom rail that came with the bed at purchase.
Mar 10, 2011 | Sorelle Vicki
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
Jun 29, 2010 | Delta Soho Crib
How do I convert from a crib to a toddler bed? Do
It is very simple to convert a crib to a toddlers bed. You just need to remove the side railings by folding them under the bed. It would be automatically converted to a bed that a toddler can use
Mar 03, 2010 | Sorelle Regal 310 Crib
Delta Martine crib conversion kit
You can order the crib rails through your local Babies R Us. We have the same crib, and have been having trouble locating them also. I spoke with the store manager today, and she said all DELTA cribs use the same rails. They are a metal pair that cost $69.99. The number for them is: 617153. Hope this helps!! :-)
Jan 09, 2010 | Delta Martine Crib
Converting crib to toddler bed
It should have come with the toddler rail when you purchased the crib.  Simply remove a few screws and take the front of the crib off (what would be the footboard).  Then simply slide the toddler rail in the tracks.
A purchase of adult rails is required to make the conversion to a full size bed for the next step.
What color is the crib?  Call at 770-974-8895 if we can help with your toddler rail.
Sep 10, 2009 | DaVinci Emily Crib
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Toddler Bed Side rail for Delta Luv 5-in-1 crib
Try calling the customer service number (212)-645-9033. I have not called them yet to get the conversion rails for our Delta Luv 5 in 1, but I'm hoping that they will know more than Babies R Us!!
Aug 02, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
yes you need to get the conversion rail. I'm looking for one if anyone can find one. I can't find a number for the manufacturer and the store I bought it from doesn't carry it anymore.
Dec 02, 2006 | Childesigns Carrollton Crib
Simplicity for Children 8994W Crib Logo
284 people viewed this question
Top Simplicity for Children Baby Gear Experts
Dennis Crouse
Joseph Hoffmann
Are you a Simplicity for Children Baby Gear Expert? Answer questions, earn points and help others
