Question about Nelson Sprinkler: Traveling Tractor
Need replacement nozzle for the rotating arm
The nozzle from one end of the rotating arms is missing. Where can I get parts
I found parts for the Nelson traveling sprinkler on ebay.
Posted on Jul 21, 2009
My Indesit dishwashers lower spray arm comes off resulting in flooding do I need new arm support
Yes. The water pressure in the hydraulic system is very important.
If more water flows through the hydraulic circuit of the lower nozzle, then probably that the upper nozzle will not rotate which will cause poor wash results.
Dado
Oct 25, 2015 | Indesit Dishwashers
Baumatic BDW13
I think that you may be on the half wash setting, check to see if the light labeled as number 4 is on while washing, if it is, then you need to simple turn off this option. Let me know if it isn't.
I will provide further assistance if needed, just let me know
otherwise Thank you for using Fixya, good luck and please don't forget to rate my solution when you solve the problem
Apr 24, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Rear wiper rotates around
the wiper arm is held against the glass by a spring-corrosion in the arm doesn't allow the spring to pull it against the glass-in order to position it properly take the arm off,run the wiper while watching it-you need 2 people for this job-noting where it starts from and where it ends at. put the wiper where it looks close to where it should be and try it you may have to reposition it a few times. as far as the wiper arm being corroded-I would replace it. the reason its going down right now is because its in the wrong position from the carwash-these things can be nasty to get off-you can get a tool at the auto parts stores-ie autozone ,advanced auto or pepboys-cheers Denny
Nov 03, 2013 | 2004 Chevrolet Blazer
The end nozzles on the sprayer on the botom of my dishwasher are blocked. Is there a way to take the bottom assembly off and clean it out?
Hi, W/D here.
Some arms are attached with caps, but usually the bottom arm attaches directly to the pump housing. I prefer to not remove the arm, as the "O" ring gasket that is part of the pump housing can be nearly impossible to get back in the grooves once it falls out.
There's still a good way of unstopping the various slots and nozzles. Use a paper clip, straightened into an "L", and use that to rake any debris out of the slots near the end of the arms. You can also use it to poke debris back through the nozzles. It may take a few times cleaning them to get it all. Several cycles should do it, however.
Best regards, --W/D--
Feb 09, 2011 | GE Profile PDW9880NSS Stainless Steel...
Upper arm does not spin
Hello, W/D here.
Usually, the reason the arm doesn't spin is due to pluggage in the arm. The arm has two features, the spray nozzles, and the slots along the edges that cause them to move. Check your arms for pluggage. If you can remove it, do so and clean it over the sink. Use a toothpick to unplug the nozzles and slots. Pick out what you can, and backwash the slots and nozzles with water from the faucet. Washing several times gives better results. Wash back towards the center of the arms, and from the center out towards the tips. Some of what's missed the first round of washing will re-appear at the tips and nozzles, so it's important that you take your time, and be thorough.
Please feel free to rate this solution. Thanks.
Feb 05, 2011 | Maytag Dishwashers
Clutch pedal has no pressure
1991 Golf has a cable clutch, the cable pulls up on the arm you see outside the transmission. the arm rotates a shaft in the very tail end of the transmission which actuates a rocker arm which pushes a pushrod that travels up the center of the transmission and operates the clutch.
very complicated right?
anyway, the rocker arm in the tail end of the transmission is famous for cracking along its' splines and jumping over the shaft.
go to the local vw dealer or jobber who specializes in german parts.
you need the rocker arm and the cover plate for the end of the tranny.
remove the clutch cable from the arm, remove the end plate and you'll see the rocker arm, unclip the shaft, remove old rocker arm, and replace. should cost a maximum of $30-40(can)
Jul 08, 2009 | 1991 Volkswagen Golf
Upper spray arm detached
The upper arm clips onto the upper drawer not onto the nozzles!
Jun 21, 2009 | Siemens SE24A230 ExtraKlasse Built-In...
Broken rotating microwave arm - can't find part
That would be the support, and you can find it by entering your model number UMC5200AAS here.
Nov 22, 2008 | Maytag UMC5200AAS Microwave Oven
Spray arm does not move
the spray arm is moved by water spraying out of angled jets at the end of the arm. the mostly cause of no rotation is these jets being blocked - its not always obvious. remove spray arm and run water into centre hole and see if you can see anything blocking the jets
Apr 15, 2007 | Candy 24 in. CD622 Free-standing...
Nelson Sprinkler:  Traveling Tractor Logo
438 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
