Question about Nokia 7373 Cellular Phone
PIN (Lock out)
So, my brand new Nokia 7373 shuts off today. The only problem is that I never put an new PIN code in. So, I figured that it would be the standard 0000 code like in all other cell phones i've ever seen. Turns out, I'm not so lucky...
How the heck am I supposed to get back in to my phone?
    Problem Solver:
  • 16 Answers
Re: PIN (Lock out)
Thge master code solution DOES NOT WORK! i work in the mobile phone repairs sector and can tell you that the only wa\y to recover sim lockouts is to call your network provider and request the puk code which you type in and it will reset your pin code on the phone
Posted on Dec 10, 2007
  • 4,102 Answers
Re: PIN (Lock out)
If you give me your imei number off the back of phone under battery looks like 123456/12/123456/12 and also the code number looks like 123456 also on back of phone i can give you master overide code this will allow you to use the phone and reset the security code
Posted on Nov 26, 2007
0 characters
3 Points
Whats the restriction code for a nokia 7373?
You can get the Restriction code for NOKIA 7373 at and get the Instructions at unlock it step by step.
May 27, 2012 | Nokia 7373 Cellular Phone
After entering in the reset code the phone requests for the security code av tired 12345 , 00000 , all av failed . wat is the security code for nokia 7373
- To unlock you Nokia 7373 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of
this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by
typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Sep 14, 2011 | Nokia 7373 Cellular Phone
Does anyone know the unlocking code for a nokia 7373 thanks
Hi there, by logging on to the website, you will be able to get unlock codes for your Nokia 7373 model mobile.
Jan 13, 2010 | Nokia 7373 Cellular Phone
Want to unlock my phone online
This is a simple way to unlock your mobile.
This having the code and instructions for nokia 7373 mobile.
After open this page you have to select your country and network.It shows details.It is also an low cost.
Apr 27, 2009 | Nokia 7373 Cellular Phone
Nokia 7373
I bought Nokia 7373 on ebay, not unlocked, my mistake! So after a lot of searching I found, PIN and PUK numbers usually come into play if you enter something the phone doesn't like, so I suggest you email them they charge £3.99, they need to know IMEI code and provider model and make, seems to me you have those, then £3.99 credit card or paypal and they unlock. If they cannot do this they refund your money. I discovered Nokia 7373 needs BB5 cable, but it may be different for you. Good luck
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Apr 16, 2009 | Nokia 7373 Cellular Phone
Unlock security code
go to the link below to get your master code by simply filling the IMEI number
rate it
Sep 09, 2008 | Nokia 7373 Cellular Phone
Trouble with my nokia 7373
Check if it is charged as when my battery is low it puts my camera on standby x
May 03, 2008 | Nokia 7373 Cellular Phone
Nokia 727 PIN (lock out)
if it ever happens again and when the switch the phone on and it ask for the security code i can give you the overide code so if you get stuck post again ok hope this is some help to you
Nov 19, 2007 | Nokia 7373 Cellular Phone
Security code
security code on a nokia is 5 digits try 12345
Nov 04, 2007 | Nokia 7373 Cellular Phone
Nokia 7373 Cellular Phone Logo
136 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
