Question about Goodman Heating & Cooling
I can't find a part number for my goodman ac condenser motor
    Problem Solver:
  • 18 Answers
Very easy get the model and serial # of which unit the indoor or outdor look on the net for a authorized dealer and call them with the info ....with any motor problem i have usually take it out and bring it a motor supply company and match it up with no problem
Posted on Jul 19, 2009
Why would my goodman gas furnace leak water from the panel that the blower motor is attached to?
the only reason water would come out of your furnace is if you also have your AC in the same system, and the condensation line is not allowing the water to drain properly.
If the water only happens during cooling, clear the condensation line. If it is happening during a heating cycle you may have an improperly connected thermostat, a bad control board, etc...
Nov 16, 2014 | Goodman Heating & Cooling
Goodman serial numbers
Serial numbers are visible on equipment where you see a permanently attached tag.
The tag will also give model number, motor amps, and other information.
Should say serial number or ser. no.
Jun 30, 2014 | Goodman Manufacturing Goodman R410A 14...
Goodman aepf426016aa
Communication problem. You say condenser stat and power are fine? if that means the condenser runs but the air handler doesn't that means the communication is good and the blower is not running. That may be a capacitor (you must have ammeter capable of checking microfarads) if not that check power it may be board driven. If no power to blower the board is bad assuming power is at board. If that is ok the blower motor is bad.
Nov 29, 2013 | Goodman Heating & Cooling
My Goodman ac unit is still running but it just feels like the fan not ac. We don't know the problem but guessing the dual Air conditioning/heat Pump (CapacitorGSC130421AC) is bad. Please advise! Thank you...
If the fan motor on the outside condensing unit is running, but the compressor is not coming on, then yes, most of the time it is just a capacitor. It could also be the compressor has a short or bad valves. If the compressor comes on in the beginning, but shuts off while the fan motor is still running, then you could have a low/high charge, and the unit trips the internal overload switch because it overheats. Hope this helps.
Jul 01, 2010 | Goodman CLQ36AR49 Air Conditioner
My AC unit comes on, but the fan doesn't work or blow air
The condenser fan motor has gone bad... this is a very common problem. Find the specs. on the side of the motor and then get a replacement from Goodman or from a company like www.grainger.com
The fan motor is rather easy to replace, the worst part is getting the fan blades off of the shaft of the old motor. Use WD-40 and be patient...
heatman101
Apr 07, 2010 | Goodman CKL24AR24 Air Conditioner
I HAVE A GOODMAN CK-36-1A AC AND THE FAN IS NOT WORKING. WAS TOLD TO REPLACE THE CONDENSER CAPACITOR AND IF THAT DID NOT WORK REPLACE THE THE CODENSER FAN MOTOR. THE COMPRESSOR COMES ON BUT SHUT DOWN WHEN...
Goodman unit you can use a 1/4 hp or 1/3 hp cond. fan motor but it does sound like a cap. Replace cap first. Its very easy to do just open up panel and replace the silver bullet with terminals out the top. It will say on the side what size it is like 40uf 5uf or something like that. Thats most likely your problem. Russ
Aug 14, 2009 | Heating & Cooling
I need a fan motor for goodman AC compressor model #CK-42-1C Serial number 9905596387
depends on where you live there are supply houses that carry goodman products the motor is a 3 1/2 ton unit or bring the motor to motor shop they can cross reference that number to another motor that would work fine
Jun 30, 2009 | Heating & Cooling
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
50 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
