Question about Cool Attic Dryers
I just installed a master flow attic fan. I ran
I just installed a master flow attic fan. I ran it for a minute or two and it started loosing air flow. I turned it off and now when I turn it on it just buzzes. Any ideas what I need to do to resolve this problem?
Sounds like it could be a bad capacitor (black box on side of motor).
Posted on Aug 31, 2009
Unit fan in attic will not stop running
if the thermostat is calling for cooling the fan will run 24-7
May 13, 2014 | Goodman Heating & Cooling
Car wont start
Change the master air flow Censor ...might be dirty
Oct 31, 2012 | 2004 Mazda 6 Hatchback
Wiring a master flow PT6 thermostat to attic fan
I had a roofer install Master Flow PRO 3 and he did the initial wiring incorrectly. The black wire pairs were incorrectly connected and caused the fan to run 24-hours. I switched the black wires pairings and the fan shuts off if less than 100-degrees (the setting I chose) and comes on if more than 100-degrees. You may want to be sure that the black wire from the power source is connected to the black wire for the thermostat (black wire nearest the thermostat setting switch and closest to the power source wire). The black wire from the fan motor should be connected to the black wire closest to the fan motor's wire.
Aug 01, 2012 | Cars & Trucks
How do we install a solar attic fan to our house?
If you have basic carpentry skills it is a 6 on a scale of 10 for difficulty. You must cut a hole in your roof, install the fan and flashing that comes with the fan then replace the shingles that were removed in the process
Jul 06, 2012 | Honeywell Solar Powered Gable Mount Attic...
When installing an attic fan do the existing air circulating vent fans and the ridge vent have to be removed? dennisa1963@hotmail.com
That depends on the location of the attic fan... if you install it in the ceiling of the house and have it just blow into the attic then the fans up there will be fine to let them there...
heatman101
Jan 25, 2011 | Heating & Cooling
Attic fan problem
The belt may be slipping and reducing the flow of air
Aug 16, 2009 | Heating & Cooling
Attic fan stops running after one hour
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Oct 12, 2008 | Ventamatic Direct Drive Whole House Fan...
Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
Aug 16, 2008 | Hampton Bay 24002 Ceiling Fan
Shutters closing while running
The shutters should be gravity closed, which means they are counter weighted just enough to close with no air flow...  when the fan starts, it will create a slight pressure differential across the shutters - when that pressure overcomes the counter weight, the shutters should open...  I assume you open windows and/or doors when the fan runs...
I would check for the following items: a) (unlikely) check to see if the counter weight is adjustable, if so, it may be slipping and needs reset.. I think this is unlikely as I think most shutters do not have adjustable counter weights -- check last)
b) check your attic vents to the outside -- the air being blown into the attic must escape to the outside world, otherwise it will build up pressure and the airflow will drop or stop altogether -- this sounds like what is occurring, at slow speeds, there is insufficient airflow to open the dampers, at high speeds, they open long enough for the pressure to build up and then they close as the air flow diminishes
c)  have you replaced windows, caulked up windows, made any modifications to reduce the flow of air into the living areas -- air must enter the house just as air must leave the attic (assumes you don't open windows or doors)
d)  if you have a fireplace, check to make sure some animal or other hasn't plugged up the chimney -- if the house is tight, the attic fan will pull air from the chimney unless it is blocked
hope this helps...
Jul 25, 2008 | Ventamatic Direct Drive Whole House Fan...
Dryers Logo
1,171 people viewed this question
Top Cool Attic Dryers Experts
Are you a Cool Attic Dryer Expert? Answer questions, earn points and help others
