Question about Philips Televison & Video
Projector Adjustment for Magnavox 51mp392h/17
I recently moved and since then it seems as if the projector is pointed down about 1/2 an inch or so. I cant seem to move the picture up so that I dont have any cut off at the bottom. The colors are great however, no offset at all. Just the overall picture is slightly lower cutting off the bottom.
Is there a way to manually adjust the picture?
  • 147 Answers
This requires secret codes not given to the public.call a tech.to repair your tv
the plublic can not repair tvs.this web site is a joke.
Posted on Jul 19, 2009
Kodak 650H projector - will cycle when the button is pushed to advance, but doesn't stop when the shutter is open. Rather it seems to keep moving until the shutter is in the closed position. The slides...
Sounds like a timing problem to me.... There is an adjustment you can make, but it's a "trial & error" fix: you have to make an adjustment one way or the other in the camstack, and then see if it's worse or better (relative to a correct slide cycle). This adjustment is made with the projector upside-down with the bottom cover removed. Check out the attached picture for more detail on where & how to make the adjustment.
Feb 09, 2014 | Kodak Office Equipment & Supplies
My 48 inch Magnavox HD is showing double Model #: 51mp392h/17
If it looks anything like the picture (3D etc) it will need the "Convergence circuit" repaired.
Let me know if you have questions.
Feb 26, 2012 | Philips Magnavox 51MP392H Rear Projection...
Philips 51MP392H/17 - Red lines on the screen. When I block the red projector the lines go away and the picture is fine (aside from the color)
You have a red drive problem or possibly a bad red tube. There are a lot of parts between the signal processor and the red tube so it is hard to say what exactly is the problem. Have a shop check it out for you. Thanks for using fixya.
Dec 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
The screen is starting to have red and green blurring
sounds like the coolant if it appears as halos. If it appears like a 3D picture its the convergence ICs.
Jan 30, 2009 | Philips Magnavox 51MP392H Rear Projection...
Rear projector tv rear blue projector wont focus
Look into the top of the tube. Probably has fungus growth. Do a search. I posted that solution many times this week for that. Normally, focus don't go out on T.V's by themself. Either the tube is bad or has fungus or the screen control is bad.....but very rare will focus part fail...usually brightness/screen is at fault. Don't forget to check the green tube as well when looking. Take the back off and see if your head will fit. If not, a large mirror will do just fine. Put something on with writing displayed....easier to tell that way.
Dec 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnavox 51" Projector TV. Model 51MP392H/17
Hello bullmuscle,
This is a power supply problem, I would suspect the HV power supply because the primary and secondary supplies anymore are tied to the HV power supply. This type of repair requires certain pieces of equipment, to test voltages, look at signals, and to if need be test for shorts in inductors (Switching PS transformer and Flyback transformer). I would not recommend that you try to fix this yourself, The cost for this type of problem is not that expensive and can be done in one evening, if the parts are available. You may be fortunate and it could be just a blown fuse, in the HV or LV power supply circuit
I hope this helps,
Thank you,
Shuttle83
Jul 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51MP392H/17
No, if the Red doesnt adjust with the remote, You will need to replace both STK392-120 Convergence ICs. Its a fairly easy job if you have basic soldering skills, and you will also need about four 6.8 ohm 1 watt resistors for your model. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Jun 16, 2008 | Televison & Video
Magnavox 51mp392H/17 convergetnt problems
When I turn on my magnavox 51mp392h/17 the sound and picture works but there is a sizzling sound coming from inside of the tv I looked and the sound is coming from what looks like a coil it has 4 lines coming from it 3 of which go to the color projectors and one to what looks like a transformer. Can you help me out?
Jun 06, 2008 | Televison & Video
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
