Question about Canon PIXMA MP470 All-in-One Printer
My MP470 Pixma won't feed paper, it pulls right
My MP470 Pixma won't feed paper, it pulls the right side in then jams. Is there a solution?
Based on instructions from your website I pushed a letter sized piece of thin cardboard backwards through the paper feed rollers then shook the printer while holding it upside down. A Q tip fell out, problem solved.
Posted on Jul 30, 2009
How to fix Canon Pixma MP470 printer that does not feed paper properly to print from Windows PC
Open up the printer and see if there is a small piece of paper that is interfering with the paper path. You may have to use a flashlight to see it.
Sep 10, 2014 | Canon PIXMA MP470 All-in-One Printer
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
My paper jammed, I (of course being inpatient) pulled it out and now the paper wont feed. Please help.
To fix the error 5200 or E2 or paper won't feed
1. Open the cover printer
2. The right side of the printer, there is a round plastic. Rotate the plastic or gears, as opposed to clockwise
3. Rotate the gears, until you hear the a voice from the right side of the printer (voice shifting gears on the right side of printer). Aiming to restore the position of the skid gear.
I hope this information helps. Thanks.
Oct 18, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hi I have a cannon mp470 and it will not pull paper through to print. It either doesn't catch at all, or it will jam to one side.
Hi
There is something stopping the paper feed process. Try the following
1. Check and make sure nothing is fallen inside the paper tray
2. Remove anything stuck
3. Even if you are not able to see anything stuck tray to use a air blower and blow air in the tray this will remove anything stuck.
Jul 15, 2011 | Canon PIXMA MP470 All-in-One Printer
Paper feeds incorrectly the feeder is pulling to the left and causing the paper to jam or to tear.
Sometimes dried ink on the roller causes it to incorrectly "grip" the paper, making it slip in one section and pull to the side, Check the rollers for Ink and other dirt.
Also try less paper in the feeder, it may simply be too much and is not able to feed it correctly.
Hope this helps GM
Apr 10, 2011 | Canon PIXMA MP470 All-in-One Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Hello my printer mp470 keep saying error paper output slot the paper is jammed clear the paper nad press ok i did all that and its still saying the same message do you have a phone number that i can call
Please follow the instruction given below ...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 01, 2009 | Canon PIXMA MP470 All-in-One Printer
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon PIXMA MP470 All-in-One Printer Logo
1,035 people viewed this question
old marine
old marine
