Question about Samsung SM 352 CD-RW/DVD-ROM Burner
I need the jumper settings for CD-Master 40E MODEL SC-140. FCC ID A3LSC140B Thank You
  • 442 Answers
When you look at the cdrom driver connectors, the following are the right jumper setting for all CDROM drives.
Left - Cable Select
Middle - Slave
Right - Master
Posted on Jul 19, 2009
Error Message: Drive 2 not found: Parallel ATA, PATA-0 (PRI IDE MASTER)
Anonymous,
Did you set the jumper on the drive to cable select? Check to what the jumpers on the back of the drive is set to. You should have 3 selections. primary,secondary and cable select.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 21, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
Will a samsung sc 140 in a dell inspiron 531
Hi Grannyking - Sorry, the answer is no. Your PC only has connectors for drives using the current standard SATA connectors. The Samsung SC140 uses the old IDE standard for connections so there is nowhere to connect the Samsung,
Regards, Mikeyaf
Mar 06, 2011 | Samsung SC 140 (SC-140) Internal 40x...
How to set as master
u need change in the mother board settings by seeing IDE 0 / SATA 0 , 1 or change in device in jumper settings by seeing in the device cover.
Apr 17, 2010 | LG GSA-H10A Burner
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
I need a registration code for my nokia6020 ?
need a restriction code of nokia model 6020
Mar 14, 2009 | Nokia 6020 Cellular Phone
Cd-rom
It is only a CD rom is a reader not a writer you can't burn data through it..
Feb 28, 2009 | Samsung SC 140 (SC-140) Internal 40x...
Samsung SC-140 driver......
the drive is no loger in the C drive????
it must not be in MY COMPUTER.
check the Data cable or the power cable of the Drive.
and go to setup utility page and see if it is detected.
Nov 27, 2007 | Samsung SC 140 (SC-140) Internal 40x...
Samsung SM 352 CD-RW/DVD-ROM Burner Logo
1,165 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
