Question about Sport & Outdoor - Others
My yamaha warrior knocks real loud when at idle speed. valves look good. have some play n the crankshaft.
    New Friend:
  • 180 Answers
Check the rings also oilpump
Posted on Jul 19, 2009
I have a 1989 dodge caravan 3.0 and it got low on oil and started knocking i took the valve cover off and it has hydraulic lifters and one of them is real soft would this mean a bad one and the cause of...
Most probably the lifter has gone bad, but if it is a LOUD knocking sound, it is possible one of the crankshaft / connecting rod bearings has been damaged. Usually a bad valve gives more of a "clicking" sound.
A bad camshaft lobe will also cause a "knocking" sound usually with an engine with high mileage.
Feb 03, 2015 | Dodge Cars & Trucks
What would cause 99 r1 to idle rough when warm
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/104-04-06-r1-mechanical-help/333978-rough-idle-knocking-engine-cutting.html
Stalling rough idle when hot Suzuki GSX Motorcycle Forums Gixxer com
1998 1999 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 19, 2014 | Yamaha YZF-R1 Motorcycles
Correct idle rpm for 2003 roadstar warrior
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
idle speed
RoadStar start up idle
http://www.rswarriordocs.com/manuals/WarriorServiceManual-WO3646.pdf
http://www.rswarriordocs.com/manuals/warrior_owners.pdf
Apr 14, 2013 | 2003 Yamaha Road Star Warrior
1998 yamaha warrior shut off while riding
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
Yamaha Warrior Won Start
http://www.atvriders.com/vbb/archive/index.php/t-158534.html
Yamaha XV1700PCRC Service Manual
Yamaha XV1700PCR Road Star Warrior Owner Manual
Aug 15, 2012 | Yamaha Road Star Warrior Motorcycles
Fix ruff idle on 2005 -1700 Yamaha Midnight Star
Hi, Elmer and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rough Idle and Engine Noise
Deceleration rough idle while cold
Jul 07, 2012 | 2005 Yamaha Road Star Silverado
1992 Yamaha Warrior 350 sound when letting of throttle!??
Check spark plug, that sounds like it's running little too lean.
May 30, 2017 | Yamaha 2004 Warrior Base
Ok. Last night my car started making a knocking noise. Its not loud and only happens when im in idle. Also it seems to come from the bottom of the engine. Help?
if it gets louder and faster as the engine speed increases then a piston is knocking...if it is just at idle like you said then it could be a bad oil pump if oil light is on at idle or it could be the connecting rod knocking on the crankshaft because it is loose.
Oct 23, 2010 | 1999 Pontiac Sunfire
2005 kia spectra wont start. throwing codes 1505, 1507 and an emissions evap. short code. what is the possible fix?
P1505 - Idle-Speed Control Valve Closing Solenoid Control Circuit Electrical
P1507 - Idle-Speed Control Valve Opening Solenoid Control Circuit Signal Low
The knock sensor will cause the ignition timing to ******, which will cause a lack of power, however, it's important that the engine camshaft/crankshaft timing was set properly when rebuilding the engine, if this is off, the engine will have no power and you could set the knock sensor code.
Hope thats help.
Feb 24, 2010 | Kia Spectra Cars & Trucks
My 2001 Yamaha warrior yfm 350 makes a loud ticking noise coming from the motor, what is wrong with it????
had the same thing on my 350 the adjustment screw for the valves had backed out had to readjust them and replace lock nuts
Nov 03, 2009 | 2002 Yamaha Road Star Warrior
Sport & Outdoor - Others Logo
82 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
