Question about Hamilton Beach BrewStation 47214 Coffee Maker
Hamilton beach brewstation is leaking
I really like the brewstation 12 cup and would like to repair it.
i seen coffee all over my counter top when i came home from work.
i tracked down the problem and found there were small cracks where the screws hold the heating plate to the gasket. i originally thought it would have been a gasket seal problem but found that 3 of the 6 screw hole areas had very small cracks so im guessing i will have to replace the tank.
any ideas ?
  • 3 Answers
SOURCE: parts for Hamilton Beach BrewStation® 12 Cup Coffeemaker With Timer
http://forumappliances.com/images/Hamilton%20Beach/Hamilton%20Beach%20Parts/Hamilton%20Beach%20P-990021600.jpg
It's called a tank, not a pot. $9 CDN. Haven't been able to find in US yet. This is very hard to belive considering they make so many small appliances I think HB is not making parts available intentially to get consuners to buy again. Not sure this is smart.
Posted on May 16, 2008
SOURCE: Hamilton beach brewstation
I found this site that calls it a "permanent dispencing filter" but the small print says that it is the small domed filter that sits on the bottom of the tank so I sounds like the same as the filter screen. FYI, there is a pricing conflict when you click on the part. The part link shows that it's $4.99 but when you select the part or try to order it, it comes up as $5.99. Here's the link http://abtecparts.com/hamilton_beach_brew_station_filters.htm
I will probably still call HB tomorrow and see what the want for it before I buy.
Posted on Aug 03, 2008
SOURCE: Need to clean my coffee maker
me to dont know, sorry
Posted on Dec 18, 2008
  • 3 Answers
SOURCE: Leaking Coffeepot
I have the same leaking problem. I just called Hamilton Beach and gave them the model and serial numbers. They are sending me a new "gasket" complimentary but she said if that doesn't work, I'll have to order a whole new coffee tank.
Posted on Apr 09, 2009
SOURCE: Hamilton Beach Brew Station 47665
i had similar problem. i removed screws and rubber seal on tank, and located a hair line crack near rubber seal, a dab of crazy clue seems to have solved this problem for now
Posted on Jun 14, 2009
Hamilton beach brewstation leaking
Sorry but if this company is like the BUNN corp there are not parts available to repair. they want to sell new only.
Nov 17, 2015 | Hamilton Beach BrewStation Deluxe 47474...
How do I get a copy of a manual for a Hamilton Beach Brew Station Deluxe Model #47454 ?
The manual is available on the Hamilton Beach product page: http://www.hamiltonbeach.com/coffee-makers-legacy-products-brewstation-deluxe-12-cup-coffee-maker-47454.html#careguides . (If needed, click on the Use and Care Guides tab.)
The direct link to the Use and Care Manual is http://useandcares.hamiltonbeach.com/files/840160504.pdf . (Note: Adobe Reader or a similar program is needed to read or print the manual.)
I hope this helps.
Feb 24, 2015 | Hamilton Beach Brewstation Brew Station...
Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Dec 26, 2011 | Hamilton Beach BrewStation
We have a Hmilton Beach 12 cup Brewstation that has leaked all over the counter with every cup we pour, from the very beginning. This is our second unit and we did not hve this issue with our first one. We...
I have gone through 2 of those machines. The first one had the same problem, so I took it back and got another which also performed the same way. The resolution for the second one seemed to be to make sure no coffee or water was left in the resevoirs and the machine has to be unplugged after each use. We only use the machine outside/or when we're camping. And now that's it's not ruining my countertop, it seems to be okay. Since I had already returned the first one I decided to just deal with it. Best of luck to you.
Aug 22, 2010 | Hamilton Beach BrewStation 47214 Coffee...
I have a brewstation 12 cup coffee maker,Everytime I pour a cup, it will leak. Is there a sulution to this problem?
If you open up inside it usaully is the little plastic hose is crack needs replacing.Do it your self go to Lowes or Home Depot get assistants there and show them the hose size.Good luck!
Aug 08, 2010 | Hamilton Beach BrewStation 47214 Coffee...
HAMILTON BEACH BREWSTATION LEAKS FROM SPOUTS
I had the same problem with this same machine. On this model there is a spring-loaded piece of plastic that operates the pouring of the coffee. After a few months of regular use, there is a design flaw in this piece that wears out prematurely, causing the pour to slow down. This is why the stream runs towards the machine and not in your cup.
Eventually the plastic piece will break at the weak point and will stop pouring altogether. To make matters worse, HB uses a weird screw that you cannot turn unless you have the right bit, and, once you do finally get to the piece, there is no where to order a replacement.
Summary: Hamilton Beach built an intentional flaw that is difficult/impossible to repair so you will need to purchase another machine in under a year.
Jan 24, 2010 | Hamilton Beach BrewStation 47224 Coffee...
Brewstation Leaks
Mine did the same thing, except I have the model #47665 because the model you have I had to replace twice. It would start/stop numerous times during brewing. Anyway, if yours leaks coffee the same as mine it's because the tiny plastic part holding the small rubber gasket that controls leaking (inside the tank under the screen) is most likely broken. Apparently it's a common problem. I called HB at 1-800-851-8900 and talked to customer support. They are sending me a whole new tank (cannot just fix the gasket) for the whopping price of $5.00 to cover shipping. That's right, $5.00 for shipping gets you a whole new tank. I love Hamilton Beach. They truly do stand behind their products. Again Hamilton Beach product support, 1-800-851-8900 good luck to ya........Katherine
Jul 12, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Parts for Hamilton Beach BrewStation® 12 Cup Coffeemaker With Timer
Feb 12, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton Beach BrewStation 47214 Coffee Maker Logo
445 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
