Question about Garden
Wont start and has no spark,have fitted new spark plug
  • aur33iga Jul 19, 2009
    no spark on a rover mower,have tried a new spark plug
  • 116 Answers
Take cover off fly wheel area and sand rust off from around fly wheel should take care of it
Posted on Jul 20, 2009
Hyosung ms3 250 battery fully charged engine turns over wont fire up also new spark plug fitted
has spark? has fuel going to carb? if you smell gas from the muffler or carb then it not burning check for spark pull plug touch away from the hole so you don't ignite the vapors on the engine look for a great blue red spark
Feb 24, 2013 | 2009 Hyosung MS3 250
I have a 2010 Oliver City CPI, motor scooter. The engine wont start. The starter seems to work and theres gas in it. Tried the kickstarter and wont start. bad spark plug maybe?
My problem started like this,I found No spark so changed coil,cdi,voltage reg,eventualy found stator at fault,check pick up strip on flywheel and pick up pin on black pick up coil,this is fixed to stator and sends spark signal to cdi,mine were both rusty/dirty,I fitted a new stator,but now have light problems..stator seems to be to strong.
Jul 14, 2011 | 2011 Cpi Oliver City
Hi u guys please can u help me. I have a 1988 K100LT it has just had a new battery fitted and iv just cleaned all the spark plugs put them back in the bike and now it wont start why do u this this is help...
never clean up a bmw spark plug,,,all ways fit new ones,,,have you got the plug leads on in the right order? i hope you never tryed to spin the motor over without grounding all the spark plugs first???? if you did you could have blowen up your ignition computer
May 21, 2010 | 1988 BMW K 100 RT
I HAVE A 1988 CHEVY VAN G20 5.7 I CHECKED TIMEING CHAIN NEW PLUGS,PLUG WIRES,DIST CAP, ROTOR,COIL,FLUSHED FUEL TANK,NEW FUEL PUMP AND FILTER I HAVE GOOD FUEL PRESSURE,GOOD COMPRESSION,THE PROBLEM IS SPARK,...
1/ Have you fitted the spark plug leads in the proper firing order.
2/ Look inside the top of distributor Top (this is not the first time a new distributer cap has very small crack) or the rotor arm is fitting the cap properly. Hope this helps Best Wishes, Malcolm Campbell.
Jul 04, 2017 | 1988 Chevrolet G20
Had the head redone, new Carb fitted, new distributor cover and leads new spark plugs, crank timing set to mark (0)and cam timing (2e)set to mark on head. the engine swings, fires from the carb, spark on...
Sounds like you have your timing off. If it is backfiring, that means that 2 of your wires are crossed, causing the plugs to fire on the exhaust stroke versus the compression stroke. Recheck your timing.
Jun 07, 2009 | 1984 Toyota Corolla
Got a loncin explorer 90cc quad had trouble with starting it, since i bought it from new. took it back got a new battery and starter fitted at cost was fine for a week or so, but now wont start again, its...
ive bought 1 and had the same problem , change the spark plug for an ngk , and use shell v-power petrol ( or any other high octane fuel ) myn now starts first time every time :) and go's like stink also consider buying a better battery , the standard 1's are **** !
Mar 16, 2009 | Cycling
Hyundai coupe wont start
did you change your plugs and wires?
Jan 19, 2009 | Hyundai Motor 1999 Tiburon
1987 ford f150 8yl turns over wont start
check your spark plugs are not wet with fuel if they are fit new ones
if they are not wet put fuel down the intake and try and start if it starts u have a fuel problem
Dec 16, 2008 | 1987 Ford F 150
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
