Garden Logo
B
Barry Van Posted on Oct 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I use a steel push rod instead of the aluminium one in the intake?
magna buff
Level 3:
  • Garden Master 3,828 Answers
  • Posted on Oct 10, 2016
magna buff
Garden Master
Level 3:
Answers
3828
Questions
0
Helped
1114016
Points
21593
What maker of mower or tractor
where exactly is this push rod being used or needed
on your mower or tractor
aluminum push rod has been designed to be used there for a reason
without more information
using solid steel push rod and "in the intake" in the same place
sounds risky
1helpful
2answers
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 • Garden
2answers
VS V6 valve timing position
Here is Holden\'s Alloytec V6 in glorious technical detail.
The global V6 engine is the first V6 engine program to address what Thomas G. Stephens, group vice president, GM Powertrain, says is a vital initiative: to develop world-class engines with fully contemporary features - such as dual overhead cams and variable valve timing - but at a competitive cost structure that allows use of the engines in a global mix of vehicles.
Exhaust: 111 degrees BTDC initial timing
50 crankshaft degrees retard authority
Compression Ratio:10.2:1
Bore Centers:103 mm
Firing Order:1-2-3-4-5-6
Fuel Shutoff:6,700 rpm
Engine Idle Speed:600 rpm
Fuel System:Sequential port fuel injection (returnless)
Engine Management:Torque-based; Bosch Motronic ME 9 32-bit micro-hybrid controller
Intake Manifold:Dual-plenum, equal-length with 2-position variable volume control (resonance tuned)
Throttle:68-mm single bore; electronic control (ETC)
Ignition:Individual coil-on-plug; individual cylinder knock control
Fuel Requirement:Premium fuel recommended
Emissions Controls:Dual close-coupled catalytic converters (1.15L ultra-thinwall ceramic)
Positive crankcase ventilation (PCV)
Intake- and exhaust-cam phasers (EGR)
Evaporative emissions system
Assembly Sites:St. Catharines, Ontario, Canada
Port Melbourne, Victoria, Australia
Material Applications
Block Material:Aluminium, precision sand-cast 319 with cast-in-place iron liners
Cylinder Head Material:Aluminium, semi-permanent mould 319
Intake Manifold:Upper: Aluminium, sand-cast 319
Lower: Aluminium, 356-T6
Exhaust Manifold:High-silicon moly cast iron
Camshaft Covers:Injection compression thermoset composite; vibration isolated
Front Cover:Diecast 380 aluminium; internal multilayer damping panels
Crankshaft:Forged steel
Connecting Rods:Sinterforged steel
Pistons:Aluminium, polymer-coated skirts, full-floating wristpins
Main Bearing Caps:6 bolt caps, copper-infiltrated sintered steel
Oil Pan:Structural diecast aluminium, steel windage and baffle plates
Additional features:Pressure-actuated piston-cooling oil jets
Extended-life sparkplugs, coolant, accessory belts
Cartridge-style, top-access oil filter
Oil-level sensor
Wide-range oxygen sensors
I need to know the over head vave setting for the intake and exhaust on a 17.5hp Briggs & Stratton vertical shaft, single stroke lawn mower.
hi pauly46 here
set piston to tdc compression stroke then run it down the bore a 1/4 inch
set the tappetts to inlet the bottom valve ( alloy push rod ) to a tightish 0.004" and set the
ex valve the top one ( steel push rod ) to 0.005"
setting at 1/4 pst tdc eliminates decompressor from upsetting valve clearance seting
cheers pauly46
1helpful
Order for push rods 2000 olds 3400 engine
WHEN ORDER PUSH RODS YOUR INTAKE PUSH RODS LENGH 5 3/4 INCHES , THE EXHAUST PUSH RODS LENGTH 6 INCHES. YOU NEED 8 INTAKE PUSH RODS YOU NEED 8 EXHAUST PUSH RODS. YOU CAN GO TO DEALERSHIP BUY OR AUTO PARTS STORES HAVE THEM.
2helpful
I have two rod push for a mower, one metal and the other is aluminum. do u know which goes on and the other goes on bottom
Find the intake valve...the aluminum rod operates the rocker for that valve....the steel rod is toughter of course and can handle the heat from the exhaust valve. If you have the head which valve is which will be evident...the exhaust valve will be near the muffler and sooty of course.
3answers
Welding aluminum
TIG weding is next to brain surgery as far as CLEAN goes.
You must get your AL clean, either by 1. Clean with a NEW Stainless Steel brush or 2. by using a chemical from the welding house that is made just for that.
Your cup must be clean and your gas flowing at the right amount,no leaks in o-rings or hoses.
Hold your cup more vertical and keep your filler rod in the gas shield always,no in and out movement.
In short you must get everything perfect to get quality Heliarc Al welds.
Good luck, HowardRoark
Top Garden Experts
Jay Finke
Jay Finke
john h
