Question about Frigidaire Refrigerators
How do I remove the toe plate/grille on a Frigidaire model LGHB2869LF4? I've loosened up either end but it appears to be secured in the middle somehow. Also, one of the metal clips came off.
    New Friend:
    Problem Solver:
  • 11 Answers
You just have to lift straight up, The spring clip shown needs to be put back into the toe grill on one of the sides.
Posted on Oct 25, 2016
3 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: My freezer seems to leak water from the plastic
Part 17 on this diagram is your drain trough. It is behind the evaporator. The frost melted during the defrost cycle drains through it into a tube. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Posted on Jan 01, 2011
  • 2699 Answers
SOURCE: I am able to access
get a shop vac and a condenser coil brush,you can buy it at any appliance or hardware store,you stick the brush into the coil and the dust sticks to it or falls apart onto the floor or i use a shop vac,one end vacs the other end blows,i vac up as much as i can and then blow the rest off of the coil,you can remove the bottom back panel and blow it to the back wall and then vac up the dust that blows to the back
Posted on Feb 27, 2011
Why does my Frigidaire model LGHB2869LF4 freezer temp cycle as high as 15 F? It happens at least once a week, though not each day. I notice high temps at night, and when I wake up it's back to 0 F.
that might be when the defrost cycle is kicking in , AT NIGHt . try setting the temperature to a lower setting . freezers should be well below zero
Oct 10, 2016 | Frigidaire Refrigerators
I want to move my fridge but it's locked in place. How to unlock?
Hello Tina;
My name is Peter. I am a retired field service refrigeration technician.
You did not post your model number which is located on a label on the inside liner wall of your fresh food section.
First remove the bottom grill or toe plate in front of your refrigerator. This plastic piece is either held on with one screw at each end or pop out clips. If clips pull the plate straight out about 2" from each end. This plate is easier to remove with both doors open.
Refrigerator Leveling Screws: Most refrigerators have two leveling screws in the front, one on each side. These screws are for leveling the refrigerator from rolling on the wheels. Turn these screws counter clockwise.
Refrigerator Wheel Locks: Some refrigerators have a lever bar on the outside of the front wheels to lock the wheels in place.
Refrigerator Independent Wheel adjustment Screws: Some refrigerators have two hex head screws on each side. They raise and lower both the front and back wheels.
Mar 04, 2016 | Refrigerators
How do I remove bottom grill on refridgerator
Hello;
The bottom grill or toe plate is held on in one of two standard ways.
Some toe plates are held on with two screws, one at each end. If you do not see any screws then the toe plate is held on with clips, one at each end. Pull straight back firmly at each end of the toe plate to remove.
Feb 10, 2015 | Refrigerators
How do I pull out tray behind toe grille to clean?
Hello Friend, this is Z. Thank you for allowing me to assist you!
The drain pan of your Frigidaire refrigerator (FRS23R4A) is not removable. Hope this helps! Should you need further assistance please feel free to reconnect.
Sep 01, 2014 | Frigidaire Refrigerators
Cannot attach toe plate
Hello - To remove the toe grille you will need to have the doors of the refrigerator open, the grille simply snaps into place. Remove the right side first and then the left, as the water line is on that side. When replacing follow the steps in reverse.
Nov 04, 2012 | Frigidaire FRT21H8 Top Freezer...
How do I change the water filter for ASD2522WRS
Your water filter is located underneath the freezer door, in the toe plate grille. you will see a knob, turn it counter clockwise one quarter turn. Sometimes its easier if you remove the toe plate grill first. Remove the filter from the housing, then remove the knob from the filter, place the knob on the new filter, remove the red cap on the other end, and with the "handle" of the knob pointing up and down, insert the filter, and twist it clockwise one quarter turn. Replace the toe grill if you removed it
Nov 09, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Model: Frigidaire GPDB998JC0 It fills and drains
Check your water level to see if the water valve is even filling up properly. After starting the cycle, listen when the water fillup begins and ends. Open door and see if there is enough water at the bottom. Should fill up to the float valve. If there is not enough water, the valve needs to be replaced. Costs about $25 and can be replaced diy if you are handy with pushing back the hose clamp and undoing and redoing the water line connection.
Make sure you unplug the electric, and shut off the water before you even want to look behind the toe plate. Dishwashers have high electric hazard behind the toe plate..
Jul 01, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Dryer does not heat and continues to run/will not shut itself off
This is probably due to a faulty heating element, something the average do-it-yourselfer can replace. Disconnect the power supply, then refer to the owner's manual for procedures to remove the front panel from your specific model. If your dryer has a toe-kick plate in front, that's all that needs to be removed.
1)Locate the heating element heat shield, a box on the lower right side of the dryer.
2)Using a screwdriver, pull the two screws at the front of the heat shield. Remove the front of the heat shield or, if it is on a hinge, flip it down.
3)Remove the wire leads from the heating element terminals by pulling on the leads. To avoid damaging the wires, do not grab them when you pull off the leads.
4)Remove the holding screw on the side of the heat shield that connects to the heating element.
5)Remove the heating element by sliding it out of the heat-shield box. Install a new heating element and secure it to the heat shield with the holding screw on the side.
6)Reconnect the wire leads to the new heating element by pushing them onto the terminals. Place the heat shield front cover back into position and secure it with the mounting screws.
7)Replace the front panel or toe-kick plate and reconnect the power supply to the dryer.
Aug 28, 2009 | Frigidaire Dryers
Defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Aug 25, 2008 | Refrigerators
Refrigerators Logo
321 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
