Question about Dell Latitude D505 Notebook
My power button was broken, and I ordered a new, but still does n
My power button was broken, and I ordered a new part from dell and they sent it to me, and I replace it, the whole plastic with LED and power b button, but still the power button does not goes on as smooth as it should, like something is broken down under the part that I changed
is there anything else that I need to change bellow this part?
to power up the laptop I am using an unnatural human force to push the button it self...
  • pandovska Jul 19, 2009
    Dissasseble and reassemble what? the assembly for the power button is one plastic thing, there is nothing to be dissassbled; is has to be something bellow this plastic cover, any idea what it might be?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Hi. Wouldn't keep doing that. Dissasseble and reassemble- watch instructions Something in there d not right.
Posted on Jul 19, 2009
Dell unstick power button on PC desktop
It sounds like either the push button assembly is broken on the front bezel cover, or the power switch is broken. Follow these steps to take the covers off.
Front Bezel: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/bezel.htm#wp1181855
Side access cover: http://support.dell.com/support/edocs/systems/insp620620S/Insp620/en/sm/cover_re.htm#wp1193123
Now look for either a broken piece on the bezel push button assembly or a broken power switch inside the computer case.
Dec 02, 2012 | Dell Inspiron 620 ST Desktop Computer...
Where can I find the front panel I/O switch that goes from behind the power switch to the motherboard
that is a specialized switch and it can be frustrating trying to get Dell replacement parts(I used to do Dell service in Hawaii)
this switch is unique and an on off switch is not useful at all
contact dell parts and give them the computer code(usually a series of numbers and letters) called the service tag and that should get you closer
May 26, 2012 | Dell Dimension 3000 PC Desktop
I got a dell optiplex 755 base unit from work as they were throwing them out but I cannot get a picture on 2 different monitors,no beeps no bios nothing.I connected a key board and mouse (both usb).Unit...
I recently worked with a couple of used Dell desktops that someone got from work. Sound familiar? I couldn't get them to come on because the plastic bracket that holds down the CPU heatsink was broken. The heatsink was also covered with a carpet of dust. The new owner could've bought a new heatsink/bracket online, but they declined to spend money. Open it up, make sure everything is in order to diagnose the problem.
Aug 15, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
Dell Dimension B110 will not power on when front button is pushed. Plugged it into another outlet without using power strip....still didn't start...purchased New power supply and installed still nothing...
check the bezel/power button
try to open the tower but you have to make sure that its unplugged/ after unplugging the power cable press the power button for about 5 secs to drain the flea power then check the power button maybe its broken or the cable connected to the power button to the main board is damaged or loose.
Sep 03, 2010 | Dell Dimension™ B110 PC Desktop
Stuck power button on Dell Monitor
Guru Kenny G, There are thousands to choose from in the DigiKey catalog, both through-hole and surface mount types. You should be able to measure the dimensions and order one that will work. Also try
Jameco and Newark Electronics. 12fixlouie
Mar 22, 2010 | Computers & Internet
Dell 1704FPT just went dead, will not turn on not even yellow light on power button - just seems to have died. Is there a way to reset? or is it time for a new one?
First you need to troubleshoot a little. You should first try another power cable for the monitor, if that doesn't help, you might be able to open up the monitor case and check wether the button is broken. If the button is broken, you're going to have to improvise a new one, since new buttons aren't really being sold. If that isn't the case, or if you can't open up the monitor, take it to computer shop, these things are easier to fix if you can look at it. I hope this helps, Yannick.
Jun 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Power Button Broken?
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
May 20, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Broken plastic power button
Broken plastic power button? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
Apr 29, 2009 | Dell E177FP LCD Monitor
Dell 922 AIO printer~~ does not power on when press power button all cords are connected ~~ is there a power supply in the power cord that fails ??
I had a simalar problem. On the back of the printer where the power cord plugs in it is connected to a power adapter. The adapter was burnt out. the power adapter slides out. Mine was melted easy to see. I ordered one from dell. If you do order one from dell make sure they send you the correct part. They sent me the wrong part the first time. There customer service dept. ha gone way downhill.. Regards Frank
Oct 02, 2007 | Dell 922 All-In-One InkJet Printer
922 All-inOne ink Jet printer doesn't print
Lots of luck. I couldn't even get the printer to load the software or install the hardware. I was helped by Dell's tech support (Dell has one of the best tech support programs that exists, in my opinion) for at least 4 hours without any good results. They sent me a replacement for a replacement and I finally got the printer and the software to show by installing it differently. Now it will not print, and, like you, the light to the power button blinks all the time and the printer states that there is no color cartridge installed, even though I have re-installed the new trial cartridge sent by Dell several times. I am going to purchase a new Canon Printer.
Nov 14, 2006 | Dell 922 All-In-One InkJet Printer
Dell Latitude D505 Notebook Logo
208 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
