i have a cb radio that i want to use in my house but its for a car so i need to know what i should use as a power supply also what type of antenna will i get the best reception with for this setup? thanks a million and and a half. -chris. ps. do any of you know anything about turntables?
I only have a general manual for my Cherokee CM-10 that was given to me. It has a lot of...
(More)
I only have a general manual for my Cherokee CM-10 that was given to me. It has a lot of "extras" that I have no Idea how to use. Can you help me
trc474 realistic. low volume and mod light is staying on .tx scale goes up when mic is keyed. max rf...
(More)
trc474 realistic. low volume and mod light is staying on .tx scale goes up when mic is keyed. max rf gain and minimum squelch. unit was always used with ext speaker . now using internal speaker
I suspect the speaker as well on my unit as I have it wide open and can barely hear anything. Rf...
(More)
I suspect the speaker as well on my unit as I have it wide open and can barely hear anything. Rf gain wide open a squlech is at mimmum. However I do see that the mod light is lit all the time. If I key the mic the tx scale lights up. Don`t ever recall seeing the mod light on constantly like this
Have him also try a Pa test with the spkr plugged in the pa slot to see if the mod section is...
(More)
Have him also try a Pa test with the spkr plugged in the pa slot to see if the mod section is working or not. Is the radio TX modulating? if so, wouldn't the chip still be good? One other thought, maybe the legs of the spkr jack is pulled loose from the circuit board. Good luck with it,, Mechanic
