I have a DIRECTV provider and an antennas. I just want to know how I can watch TV. Also I don't have the remote I have a DIRECTV remote.
SOURCE: Digital Tuner in Emerson EWF2004
Check this link for more info. You tv is not HD capable because it has an analog tuner and not a digital one.
SOURCE: remote tv codes
If you have an android device with an IR BLASTER you can download a universal remote app that will allow you to to switch inputs. Instead of listing the serial number the correct tv code will be listed as 1394.
10154, 10236, 10463, 10180,
10178, 10171, 11963, 11944,
11929, 11928, 11911, 11394,
10623, 10282, 10280, 10270,
10185, 10183, 10182, 10181,
10179, 10177, 10158, 10039,
10038, 10019
You haven't specified the model number of remote control you possess; that is why I send this remote controls codes.
[1] Locate the 5-digit code for your DIRECTV® Receiver
[2] Power on the DIRECTV Receiver
[3] Slide the MODE switch to the DIRECTV position
[4] Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys
[5] Using the number keys, enter the 5-digit code. If
performed correctly, the green light under the
[6] Aim the remote at your DIRECTV Receiver and press
the PWR key once. The DIRECTV Receiver should
turnoff; if it does not, repeat steps 3 and 4, trying each
code for your brand until you find the correct code
OK.
