Question about Homelite Mighty Lite Lawn Trimmer
Gas tube came out of gas tank
Do they make a repair kit?
  • 23 Answers
If the rubber stopper is still plugged into the tank pry it out go to a small engine shop and buy new gas line.Thread the new line into rubber stopper to poper length,plug filter (new)on end that is going in tank then pop he rubber stopper back into the tank body.Have done hundreds and it isn't hard,you may need sone WD 40 on stopper to thread line and popping stopper back in .Good Luck
Posted on Jul 19, 2009
How fix a gas line break at gas tank?
Using needle nose pliers slip the split line off the connection and pull out of the gas tank. If there is a filter on the end you need to extract through the gas cap opening. Purchase another gas line either in a repair kit or individual line and cut to fit. If the filter is bad, use a new kit. Insert through the gas cap opening and pull up through the supply line opening. Be sure the connection is clean then slip the new line onto the clean connection.
Sep 12, 2014 | Craftsman WeedWacker Gas Trimmer 29cc...
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
I am renting a condo with an old Weber Grill - 2 burner / LP (I think it is a Genesis Silver A ('00-01) model . I have very little gas pressure at the burner tubes. - Front tube flickers on/off with...
Yes the best option for just for you is to buy a new burner,tube kit and a new manifold kit because all the things that you said you removed from the burner must have caused alot of rust on the burner and if you keep welding the burner there will still be linkage after awhile so the best thing is just for u replace the burner.
Jan 15, 2011 | Weber Genesis Silver A Grill
I put five gallons of desil in my tank how do i locate and disconnect fuel line from fuel injector to drain/
You can disconect the fuel line under the vehicle at the fuel filter but your best option is to syphon the gas tank and get as much diesel out as possible. Then fill it up with gasoline. Having a little diesel in a gas system will not hurt anything.
Jan 07, 2011 | 1997 Ford Escort
Small hose from inside gas tank is broken
Take a piece of the old fuel line to the hardware store with you. You can either get it by buying a kit or some stores will have bulk tubing they will sell from. Good luck...Lee
May 27, 2010 | Ryobi Garden
Is leaking raw gas from gas tank
Find leak and repair or replace parts as needed. If there is a hole in the tank there are kits for temporary repair.
May 15, 2010 | 1991 Dodge Power Ram 50
Is it possible to replace a primer bulb on a homelite blower?
The bulb repair kit can be purchased a home depot or lowes, or whatever is close to your home. These can be replaced fairly easy. It is usually prongs on the backside that hold the bulb in. After pressing these the bulb will come out of the housing and disconnect the tubing from the bulb. It a good idea to replace tubing when doing this, the tubing is rotted or dried out and eventually cracks. Keep in mind where the tubing goes. One will feed from the gas tank and the other will feed the carb.
Mar 24, 2010 | Homelite Consumer Products MightyLite...
Severed tube that runs along the gas tank...
Just replace / repair the tube, it sounds like your "Vent" pipe - it's a pipe running basically from the top of the tank to the filler cap, when you put gas in it will allow the fuel to "breathe out" instead of making an air lock and splashing out of the filler. If you leave it like it is it might spill fuel, then you're driving a potential firebomb.
Jun 27, 2009 | 2002 Chevrolet Silverado
Just bought a used leaf blower, homelite, gas leaks out of the gas tank, where the gas tube fits into it.
"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
May 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Gas tank wont take gas
The fuel tank vent tube is obstruted, this tube runs down inside the filler tube, you will need to pull the filler pipe off and repair or replace it.
Jul 25, 2008 | Ford Ranger Cars & Trucks
Homelite Mighty Lite Lawn Trimmer  Logo
277 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
