FRIGIDAIRE FRONT LOAD WASHER
MY WASHING MACHINE IS MAKING A HUMMING NOISE WHEN I GO TO START IT...I WENT TO EMPTY IT OUT AND THE WATER WAS STILL IN THERE ALSO..I TOOK ALL THE WET CLOTHES OUT AND IT STILL DOES NOT START UP.
  • Anonymous Mar 28, 2008
    My front load washer will fill up and drain but not spin
Check to make sure that there is not something stuck inside the drain pump. My folks had this same problem... bought a new washer and asked me to help them throw the old one away. I put it in the pickup but before actually taking it to the dump I decided to see what I could do. I took it home and it had the same symptoms you describe. I opened up the pump and there was a hair pin stuck in there. I pulled it out and the thing runs great. My folks didn't want it back... free upgrade for me. Heh.
Posted on Aug 28, 2008
  • 213 Answers
Make sure the door is locking. if the doorswitch is bad it will not operate
Posted on Nov 19, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front load Washer Does not spin (Drains fine, Water comes in fine)
Hi John - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. The humming noise is mainly caused due to the drainage hose/pump possibly being clogged and needs to be cleaned. If not, the washer may be experiencing another possible issue with the faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
May 02, 2013 | Frigidaire FTF530FS Front Load Washer
Frigidaire washer ftf2140fs2 lights on the right side keep beeping washer wont start
Hello 2cats - First, is the drain pump making a humming noise? If so, the unit could possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Other possibilities could be a faulty door lock, timer, pump, or control board not communicating correctly. In this case I would contact a professional to move forward accurately to properly diagnose and repair the washer.
Feb 28, 2013 | Frigidaire FTF2140F Front Load Washer
Not letting the water out of barrel. making a humming noise
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 07, 2010 | Washing Machines
Washer did not spin out message E20 appeared on panel. Attempts to start just humming noise.
is the humming comming from the motror trying to run or is it just a humming sound if the machine has washed correctly upto that point then check water pump for faults and or blockage machine will not advance if water trapped in machine the humming sound could be the water pump either free spinning indicating a blockage or humming as it is trying to run indicating a faulty pump
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
