Question about Honeywell Heat/Cool Thermostat
I have turned the a/c off and the fan continues to run
  • 142 Answers
You may have turned the A/C off, but check the fan switch and make sure it is on auto, not on
Posted on Jul 19, 2009
Why does my fan continue to run after car is shut off?
Which fan are you referring to? The pusher fan in front of the radiator is tied to the AC system. If it continues to run for an extended period after you turn off the key, then there is likely a problem with the relay. I think your model year has the 2 speed fan. Does the fan run at high speed or low speed when you turn off the car? Does it do it if the AC is off?
Oct 13, 2014 | 2000 BMW 528i
Cooling fans continue to run when engine is shut off
This is normal. Cooling fans today are not turned by the fan belt but are run by an electric motor. The fan continues running until the coolant temperature is reduced
Apr 02, 2014 | 2003 Volkswagen New Beetle Convertible
Cooling fan runs continuously, even after replacing both relays coolant sensor.
Could be that you have 2 Thermal sensors as some cars have one for the dash gauge or light and the other is for the PCM.
Remember that when you turn on the A/C it can trigger the cooling fans to run continuously. If the A/C is left on while you are doing all of this, it can be a simple reason for the problem.
Please rate my info.
Jan 03, 2013 | 2002 Pontiac Montana
Why does furnace fan run continuously?
No on the thermosat go and check fan is not on the summer switch setting , if the fan is running it could be the AFC automatic fan control not shutting the fan off
Dec 29, 2012 | Honeywell Heating & Cooling
I have reno megane 04 my fan continues running when my car is not running i have had the air presureit has just happened again sensor replaced bu
Many cooling systems are designed to let the cooling fan continue to run even after shutting down the engine...however, this should only last for a minute or so...your owners manual may help. If the fan never stops when turned off this is probably a faulty resistor...may need a good mechanic to confirm which...Hope this helps.
Jul 09, 2012 | Cars & Trucks
Cooling fan continues to run after engine shut off.
The fan runs for a short time, after ignition off, to continue to cool the hot engine.
Dec 10, 2017 | 2005 Dodge Stratus
When we shut off tv for the day the fan motor continues to run it does not turn off
the fan will continue to run after the power is shut down on a DLP television untill the set has cooled down . But it should shut off within a few minutes
May 23, 2009 | Televison & Video
The electric radiator cooling fan will not turn off
As long as the fan eventually shuts off this isn't a problem,the fan will continue to run for a bit after the car is turned off,once it reaches a set temprature it will turn off.
May 01, 2009 | 1999 BMW 328 Series
AC/Heat Fan runs continuously and Rear end roaring noise
Sounds like the wheel bearing on the right rear hub may be defective, that would cause the noise if the tires are ok. As far as the fan goes not sure this isn't working as designed.
May 02, 2017 | 2005 Nissan Altima
Honeywell Heat/Cool Thermostat Logo
109 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Bill Long
richie46
Tom Chichester
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
