Question about Amana Portable Air Conditioner
Amana portable. Model 125D. flashing red light on the top. Unit would not turn on.
  • 619 Answers
SOURCE: Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Posted on Jan 30, 2008
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Posted on Aug 03, 2009
  • 10 Answers
SOURCE: Light flashes red at Portable A/C unit
drain system clogged or condensate pump no good
Posted on Sep 01, 2009
Testimonial: "The condensate pump was jammed and causing the water to rise in the tank and thus safety shut-off of the A/C unit. Freed up pump & cleaned water tray."
  • 82 Answers
SOURCE: Manual for Amana AP076E portable a/c
The manual is by Haier but you will see it is or the Amana AP76E. - http://service.haieramerica.com/documents/User%20Manual%20AP076E.pdf
Posted on May 11, 2010
Testimonial: "Great job!!"
SOURCE: model # m6p09s2a portable maytag
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Posted on Jul 08, 2010
Red Lite is flashing, unit will not turn on
if the red light is flashing this means theres a fault , most common fault on these are water catch bucket is full or not seated back correctly
Aug 24, 2015 | Amana D950EP Dehumidifier
I have an Amana AP148DS POrtable air Conditioner. Is there a way to turn off the LED light?
No, unfortunately there is not a way to disable the light unless you are to disassemble the unit and remove the light.
Jun 10, 2011 | Amana Heating & Cooling
Doesnt turn on, red flashing on top. we think it has something to do with water but cant figure out how to drain?
hello usually you have a drain tube or you may have to remove the cover and then remove the water pan by hand ,dump out and install back into slot hope this helps if not let me know
Jun 09, 2010 | Amana AP095R Portable Air Conditioner
Amana PTAC cannot be turned on.
sound like a thermister problem, however this may also be a circuit board problem, the system is controled by the outdoor board, check to see if you have a blown inline fuse in the outdoor unit, it will be under a red case in one of the wires.
Jan 28, 2010 | Heating & Cooling
Sony Model KV32HV600 No picture, no sound--red light flash on front of TV-tried disconnecting the power cord. works sometimes-usualy does not.
The red light on your unit is flashing b/c it is informing you that your unit is in need for a repair/replacement part. perhaps one of your boards are about to go completely out. Contact your manufacturer for warranty replacement or referral to local repairman.
Aug 06, 2009 | Televison & Video
Amana thru the wall ac unit won't turn off
The adjustment knob on the unit does not turn down how do you get the knobs off? Can we replace the control unit with one that is touch control? Could the problem of it not turning down be the thermostat? It is an Amana PTC153A35AD wall unit.
Jul 02, 2009 | Heating & Cooling
GPX DVD player flashing power light
Ihave a GPX portable dvd player that has a broken charging jack on the unit itself. The model is a GPX 808.
Mar 11, 2009 | GPX D1816 DVD Player
Amana AC
Jan 30, 2008 | Amana AP099R Air Conditioner
Amana  Portable Air Conditioner Logo
468 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
