Question about Kenmore 44102 Front Load Washer
Washing machine was making load noise while spinning, now it does not spin at all
  • 5,911 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you find the motor coupling still intact, the gearcase (transmission) may have failed. The repair cost (if you do this yourself) is about $150 or less. If it comes to a failed gearcase, and you wish to pursue the repair, the following link explains how:
http://www.fixya.com/support/r699497-replacing_gearcase
It seems like a lot, but its actually an easy repair. I would still begin by inspecting the motor coupling, though. This is the more common fail item.
If you have any questions, please let me know. If you need assistance in diagnosing your symptoms, post back and elaborate a bit more. I hope this helps you.
Posted on Jul 19, 2009
Washer making loud noise willnot spin cycle or drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Electrolux AWF 1435 Front Load Washer
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
heatman101
Jul 08, 2011 | Bosch Washing Machines
Spin cycle doesn't spin clothes dry. machine makes noise when it first starts to agitate but then the noise quits.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 28, 2011 | Washing Machines
Washer won't spin making a humming noise
heatman101
Sep 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
On spin cycle washer will not shift in high spin and makes loud squeeling noise
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 14, 2010 | Maytag Washing Machines
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
It doesnt spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 26, 2010 | KitchenAid KAWS700L Top Load Washer
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Kenmore 44102 Front Load Washer Logo
266 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
