Television set does not turn on manually or by remote control
  • 616 Answers
Power supply rebuild, expect to pay around $150- $200 Good luck Julio at Millenium tv (702) 736-1091 milleniumtvsvc@gmail.com
Posted on Jul 19, 2009
Codes for remote control GE universal remote24911
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Jul 23, 2014 | GE 24911 3-device Remote remote Controls /...
No remote or code. only get one channel with manual turn on.
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes.There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices.After confirming this, check the sites linked here.Both the sites have set-up code list and set-up procedure to many popular brand remote controls.Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability?Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual.Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Feb 13, 2014 | Hannspree XV32 32 in. LCD Television
Need to manually turn on Toshiba 24L4200U television in order to program new universal remote (old remote is lost)
If you've switched the set OFF with its remote control, you should have that remote control to switch it ON back. Then only, you can synschronze it with a universal remote control
Dec 09, 2013 | Toshiba 24L4200U
Code for Pluto LCD TV
The codes for televisions are found in the manual of the remote:
http://www.scribd.com/doc/65386721/Jensen-JR300-JR400-JR500-Manual
Since this remote does not have an entry for Pluto brand televisions, you can use the "Standard Step-and-Set Programming" method to methodologically test different sets to see if a generic setting will work for the television.
If one is not found using that method, then the remote is likely not compatible with that television.
Nov 03, 2013 | Jensen JR500 Remote Control
Hello I have a universal remote control for tv sanyo but I lossing de manual instruction and Iand ree program my tv. only I need how cam progarm my remote control pleaswed thanks.
Here is the steps on how you can reprogram your RCA tv remote control:
1. Turn the television on by pressing the "Power" or "On" button that is located on the set.
2. Press and hold down the "Code Search" button located on the RCA TV remote. 3. Press the "TV" button on the RCA TV remote. Once you press this button, you can release the "Code Search" button
4. Start pressing the "On/Off" or "Power" button that is located on the RCA TV remote. Keep pressing the button until the television shuts off. 5. Press "Enter" on the RCA TV remote to save the code on the remote. The remote will then control the television.
Apr 07, 2011 | RCA Universal Remote Control
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    Tengo control remoto marca philps universal y deseo activar tv marca charp que hago
    Look at the manual that came with your Universal Phillips Remote.
    You will see a set of televisions on a chart that will give you a 5 or 6 digit code. With your television on, select the "SET" button, enter the code for a SHARP TV, then press "ENTER". Your remote's little red LED should blink three times, at which time, you will have programmed your Universal Remote to work properly with your SHARP Television Set.
    For a list of codes for the URC4110 Remote Control, go to this link, (below,) and download the manual;
    http://www.retrevo.com/support/One-for-All-URC-4110-Universal-Remotes-manual/id/2881bh241/t/2/
    Nov 15, 2010 | One For All URC4110 Remote Control
    I can`t switch on my g-hanz TV
    http://resources.jvc.com/Resources/00/00/94/YA059ien.pdf This is a link to a pdf copy of the owners manual for your model television. You can find all the setting and function controls listed in the manual. To reset the television to factory settings, you must unplug it from the a/c power source for about thirty minutes. This will reset the television to the factory settings. You can do the same thing with the remote control. Just remove the batteries and press the input button continuously for about 1 minute. This will drain all the power out of the microprocessor and reset the remote control to the factory settings. You can then use the owners manuals to reset the television and remote functions.On turning on the television the interactive plug in menu will appear. From here you can set the language you want to use for the television. All of this is explained in the owners manual.You will need a pdf reader and writer to read the owners manual and the writer to make a copy for your own use. I hope this information helps you with your problems with the remote control and television. Thank you for using FixYa and have a nice day!
    Jun 16, 2009 | JVC AV-32D305 32" TV
    Hello,I need codes to the remote!
    Instructions on how to use the CODE SEARCH button:
    In this example we will say we are setting up the TV button for our television set.
    1. Manually turn the power to your television set ON.
    2. Hold down the Code Search button on the remote for 2 or 3 seconds until the light on the remote stays on (aka stays solid).
    3. Push the TV button on the remote.
    4. Point the remote at your television and slowly press POWER until the television turns OFF.
    5. Press the ENT button on the remote. (It is under the number 7 button.)
    or for your actual codes, go to:
    PHDVD5 CODES
    http://www.replacementremotes.com/store/productdetailp.cfm?productid=6113
    Jan 29, 2009 | Philips PH-DVD5 Remote Control
    Manual Controls Insufficient
    What is your universal remote control? if its not philips magnavox you try this universal remote control you will set the code match to your tv sanyo which you will see at the back of the instructions manual when you buy this remote control. follow the instruction of the manual on how to enter the code for tv. thanks.God bless you. i hope it will help.
    Jun 11, 2007 | Sanyo DS20930 20" TV
    Televison & Video Logo
    43 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
