Hi there. I have a problem with my Rheem Classic
Hi there. I have a problem with my Rheem Classic series ''gas-pack''. It is model # rrma-a042jk10e. The a/c is on, the fan is blowing air in the house however the sir is room temperature. Upon looking at the unit, the fan at the top of the unit was not turning and the metal over it (mounted) was hot. A couple of smacks to it and it started turning. The air is still room temp. Inside the house, when the unit trys to draw power, perhaps to engage the compressor, the lights will go slightly dim, the unit will make a buzzing sound, then 2 seconds later the sound stops and the lights go bright again. Appears the compressor is not engaging as the unit is not making its usual a/c type sounds. Also, there is no water coming from the drain pipe. I think the compressor isn't working. I tried resetting the a/c breakers in the house (marked and identifed and did cut power to the unit) but to no avail. Same fan not working/smack the fan to get rotation, and no cold air.
    Problem Solver:
  • 18 Answers
My friend it sounds like you have a bad motor the compressor will lock out either on hi pressure or internal overload start with the outdoor motor good luck
Posted on Jul 19, 2009
What airflow does RHEEM RGLN 07eamer Furnance have? Is it downflow or upflow?
looks like Downflow
Rheem Classic Series Downflow Gas Furnace cdn.globalimageserver.com/fetchdocument-rh.aspx?name=rgln... · PDF file Rheem Classic® Series Downflow Gas Furnace FORM NO. G11-519 REV. 1 RGLN- Series ... RGLN- SERIES 05EAUER 05NAUER 07EAMER 07NAMER Standard Filter ...
Feb 18, 2016 | Filter Heating & Cooling
Is there any process needed to implement for the summer to winter thermostat settings
You didn't mention what thermostat(s) you have but most simply require you to go from cool to heat and then check the temp setting(s0 to make sure they are in your comfort zone.
Nov 13, 2014 | Rheem Classic Series 95% Two-Stage Upflow...
How do i prime the water trap on a rheem classic 90
This trap will fill itself up when the furnace runs for the first time. It does not need to be primed to make it work. If you have the drain end above another p trapped drain.
Oct 28, 2014 | Rheem Classic Series 90%...
How many pounds of reon do you put In 2011 Rheem Classic packaged ac unit
look on the mane plate on outside unit... has voltage ratings model serial type of freon factory charge etc.
Jul 21, 2014 | Rheem Prestige 14 Series 4.0 ton 14.5 SEER...
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
I have a rheem classic series super quiet 80 furnace. when the panel that covers up the control board is removed is there a reset button or sequence that mut be performed so the system will once again run.
no just repalce all the covers and then cycle to power to the unit and it should take off and go...be aware that the t-stat could take five minutes or so to recycle and star the unit also..
heatman101
Aug 11, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Classic Series Super Quiet 80 gas furnace problem
I have this same POS model. It is not the thermostat. this model is just garbage and cant wait to get something that works right. i have been fighting this thing for 4+ years now.
Dec 25, 2009 | Heating & Cooling
Heating & Cooling Logo
230 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
