Question about Garden
WHEN I TURN THE KEY ON MY SNAPPER HYDRO IT CLICKS IN THE SOLENOID BUT WON'T TURN STARTER . NEW BATTERY AND SOLENOID BUT IT WON'T START.
    President:
  • 1,273 Answers
If the battery is good and fully charged, it should turn over. If you have a pull rope as well as the starter, make sure the engine will rotate. If not, you can do the same thing by placing your hand on the air vent screen on top and twisting the air screen. If the starter was hung up, usually the solenoid won't click. Have your battery tested, make sure that it is fully charged. Although unlikely, the solenoid could be bad. I'm betting it's the battery charge.
Best regards, --W/D--
Posted on Jul 19, 2009
What should I try next? My mower will not start.
When you turn the key, do you have 12V art the Starter?
If you do, then tap the starter with a small hammer. If it cranks, then your Starter is failing
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
Craftsman Tractor solenoid clicks but won't start
could be a safety switch or a ground problem check the ground for corrosion and make sure it is tight at all places then check each safety switch they usually have one for the seat,mower deck and clutch/brake pedal
Jun 19, 2013 | Garden
1994 cadillac deville no crank
The PATS security system would prevent the engine from cranking if the system does not "see" the right chip in your key. If the system is working correctly, the light should go off after you turn the key switch on.
You should have power on the small starter wire when the key switch is in the start position.
May 02, 2013 | Cars & Trucks
Won't start battery is ok.
REmove the starter for checking . IT may require a new solenoid or you may have a dead bar in the commutator which will require a new starter.. This is evidenced by sometimes you can start easy and other time the solenoid clicks every time you turn the key and then suddenly starts. IT comes from the armature stopping with the daed bar under a brush and when it turns just enough to touch another bar away it goes
Mar 09, 2013 | 2003 Chevrolet Silverado 1500
2007 Dodge Caravan won't start.Batt. is good, all lights work, Turn key, solenoid clicks and stops, all gauge needles slowly move to max., and return to min. No codes displayed.
When you try to start it do the lights dim way low, have you been able to start it with a jump from another vehicle, unfortunately, chances are the starter needs to be replaced. How many miles does it have?
Feb 09, 2013 | 2007 Dodge Grand Caravan SXT Minivan
Car won't start. New battery installed recently. Only clicks when trying to start.
one single click any time you turn the key usually indicates a bad solenoid on the starter. A new starter will typical get you going.
A series of rapid clicks when you try to start usually indicates a weak battery. There could also be a bad connection at the terminals on the battery or even a poor connection at the starter.
If you get a single click and everything goes dead for a couple of seconds than you definitely have a bad connection at the battery.
Let me know what you find or if you have any questions.
Dec 28, 2011 | 2007 Chevrolet Tahoe
2004 ion won't start. Lights work. When I turn key don't get series of clicks, get one snap.
That symptom usually means the solenoid on the starter is bad and no longer is completing the circuit to engage the starter. A new starter will likely solve that issue. A series of rapid clicks would indicate a week battery. You can try repeatedly turning the key to the start position rapidly, sometimes the starter wil start working. You can also try tapping the starter while somebody holds the key in the start position, if the starter engages place it.
Jul 16, 2011 | Saturn Ion Cars & Trucks
Snapper that will not start. Just clicks
If it starts with the key when you jump it then it sounds like you have a bad or dirty connection in your battery cable or your battery is just too low. You didn't indicate where you were connecting your jumper cable, from the tractor battery or from another source. It could also be in your ground wire (but not if you only have to use one jumper cable). Remove the negative from you battery. Remove terminal from starter, and clean and be sure terminal is tight on the wire. Remove + cable from battery and clean. Remove ground terminal from engine, clean that connection. Check that the starter is firmly bolted to the engine.
Jul 06, 2010 | Omega Rear Drive Wheel Snapper Mowers
Garden Logo
456 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
