Question about LG WM-3677HW Front Load Washer / Dryer
Grinding noise from the drum motor
Hello, I'm getting a grinding noise from the drum motor on my LG WM-3677HW front load All-in one washer dryer. Does someone have a repair manual that I could download? Thanks.
    Habit-Forming:
  • 9 Answers
ACTUALLY HAVING THE SAME PROBLEM.
SOUNDS A LITTLE LIKE BROKEN BEARINGS but I knwo it is not that serious. Seems like lint build up in the rotation drum space between steel and rubber ring seal at front door.
Posted on Jan 08, 2010
My brand new one is doing it only after 1 week. I'm also interested in it. I'm thinking of pulling it apart and watching it and trying to find out where it's coming from exactly.
Posted on Dec 20, 2009
My washing machine does not spin and drain
becouse the water in drum machine not spining,,chek the drain motor,properly,,
Jan 02, 2014 | LG WM-3677HW Front Load Washer / Dryer
Washer say on screen LE and will not turn.. Also when manually turn the turn hear grinding noise too.
Grinding noises are bad. If you are lucky, you got an item (like an underwire support from a bra) between the inner and outer tub, which may be removed through the heater or drain openings in the tub. If you are un-lucky, your rear tub seal failed, causing the rear bearing to fail, or the shaft broke loose from the 3 arms of the spider which drives the inner wash tub. Either of those things is $$$ and a lot of work to repair, involving removal of the outer drum, seperation of the outer drum halves, and repair. (translation: minimum 2 hours labor if you've ever done one before)
Feb 28, 2011 | LG WM-2277HW Front Load Washer
Ok my LG front loading washer agitates but when it comes to spin it makes a very irritating high grinding noise and does not spin. There is no error displayed but that may be because I stop it before it...
I have a similar problem. The washer was showing error code UE, but would tumble when empty in test mode, but would not spin and made a grinding noise. The bolt that attaches the rotor to the motor was loose and the rotor was spinning on the spindle that rotates the drum. I tightened the bolt, and it spins when empty, but still gives a UE error code when full. Remove the rear cover and check the tightness of the center bolt.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
I have the same problem
I had the same problem, I changed the water discharge pump and the drain problem was fixed. I still have the loud sound during the wash cycle but it does not coincide with the drum movement. I think a will pull the wash pump to check for lint buildup. people cleaning the lint trap will avoid alot of unnecessary headaches.
Jun 23, 2009 | LG WM-3677HW Front Load Washer / Dryer
'Grinding noise when drum alternates direction
you have a bearing thats bad on drum or something is stuck between drum
Jun 10, 2009 | LG WD-16115FD Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
LG WM-3677HW Front Load Washer / Dryer Logo
463 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
