My frigidaire ac is stuck on a5 setting. What should we do?
Washer won't start. error code A5 frigidaire affinity what does it mean
Main voltage sensing failure
You will need to replace the electronic control board.
Apr 19, 2017 | Frigidaire Washing Machines
Error code A5 on frigidaire affinity washer what does it mean? already replaced lock, striker, bushings.
The voltage sensing on the control board is bad. You need to replace the control board.
Frigidaire AC model LRA187MT2. Compressor runs nonstop - does not matter what the temperature setting is. When put into fan mode displays H1 instead of the temperature. Filter is clean.
You probably have a circuit board failure. On the board there are micro-relays that control power to the compressor. And in that relay the switch that is normally open is stuck closed.
Jun 27, 2015 | Frigidaire Heating & Cooling
Frigidaire fas257q2a2
Hello Friend, I am happy to assist you!
I understand your Frigidaire air conditioner (FAS257Q2A2) is displaying error code A5; however, it appears the correct error code is AS. Error code AS typically indicates that your air conditioner is experiencing an issue with the ambient thermistor. I would strong suggest contacting a professional to check the wiring between the main control board and thermistor. A certified technician would generally replace the faulty part after proper diagnosis. Best regards! - Z
Jul 06, 2014 | Frigidaire FAC125P1A Window Air...
Displaying "A5"
Do you mean error code AS instead of A5? If so, error code AS commonly refers to a sensor issue. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage.
Dec 21, 2013 | Frigidaire FAD704DUD Dehumidifier
The fan runs, but we get an A5 error.
I think what you're actually seeing is an AS error. It's looks like A5 on the LED screen.
AS error means their is a sensor failure. So, before calling Frigidaire Tech Service
(800-444-4944), turn the Master On/Off Switch to OFF. Unplug the unit for 12 - 15 minutes.
This should give the unit ample time to reset itself. Plug the unit back in and turn the Master ON/Off Switch to ON. Now, set your controls as you normally do. If the unit starts up and runs as it should, the problem for now is solved. If it keeps re-occurring, contact Frigidaire Tech Service.
Apr 06, 2011 | Frigidaire FDF50S Dehumidifier
Paper tray holder paper size stuck at a5. will
Did you ever get it fixed? Mine is having the same problem!
Apr 22, 2010 | HP LaserJet 3600dn Printer
Ex c&w codes
00= 6B 77 17 7C 6D 2C AC 92
01= A5 5F 0A 63 A5 8F 15 8D
hope these help.
Nov 27, 2008 | Directed 434MHZ Remote Control
Telepest codes 26 nov here
code for t/west please gone off again 26th nov 2008 approx 4 30pm
Nov 26, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview 1 box
C&W 27/11/08
Key 00 = 6B 77 17 7C 6D 2C AC 92
Key 01 = A5 5F 0A 63 A5 8F 15 8D
TW 27/11/08
Key 00 = E8 25 93 B2 6A 90 0E A2
Key 01 = 16 CF 0C A7 A7 14 D2 22
Aug 06, 2008 | StarTech.com StarView SV211K 2-port KVM...
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
