Question about Dell Inspiron 1525 Notebook
What is the key with the windows symbol on it
IT HAS BEEN DISABLED. HOW DO I ENABLE IT?
    New Friend:
  • 69 Answers
Hi Marci, there used to be a Microsoft Fixit download that you could download & run to resolve this issue, but MS retired it.. Follow these instructions and this will also resolve this issue:
To enable the Windows key, follow these steps:
  1. Click Start, click Run, type regedt32, and then click OK.
  2. On the Windows menu, click HKEY_LOCAL_ MACHINE on Local Machine.
  3. Double-click the System\CurrentControlSet\Control folder, and then click the Keyboard Layout folder.
  4. Right-click the Scancode Map registry entry, and then click Delete. Click Yes.
  5. Close Registry Editor and restart the computer.
**SEE SCREEN SHOTS***
Please reply with results and mark Helpful
Thank You
Doug
what is the key with the windows symbol on it - key-windows-symbol-phpl4x1vytofgz1f231vdhlm-1-0.jpg
key-windows-symbol-phpl4x1vytofgz1f231vdhlm-1-5.jpg REBOOT
Posted on Oct 09, 2016
SOURCE:
Disable num lock
Deskop or Laptop seems to be a contradiction >????
The num lock (number or numeric lock) can become annoying if you tend to accidentally hit the num lock key on your laptop and turn it on or off.
Disabling the num lock completely involves editing the system registry.
Before performing such edits, always save and back up your computer information in case you make a mistake, as the system registry controls many aspects of your computer's operation.
Once you have disabled the num lock on your laptop, you must edit the system registry again to re-enable that function.
Close all windows and programs that are running on your computer.
Press the "Windows" key and the "R" key simultaneously to open the "Run" dialog box.
Type "regedit" without the quotation marks, then press "Enter."
Click the "+" symbol next to HKEY_CURRENT_USER, then select the "+" symbol next to "Control Panel."
Click on "Keyboard."
Double-click "IntitialKeyboardIndicators."
Enter "0" (the number zero) in the "Value Data" field to disable the num lock after logon, or enter "1" (the number one) to disable the num lock entirely.
Click "OK," then close the registry by clicking the "X" in the upper right corner of the registry window.
Restart your computer.
To re-enable num lock, follow the same process, but change the "Value Data" to "2."
http://www.softwarehowtos.com/article-how-to-disable-or-enable-the-num-lock-key-at-startup-1244448193.html
Oct 09, 2013 | Dell Vostro 1510 Laptop Computer PC...
Accidently disabled display screen on my laptop and also disabled the external Vga, how can I enable them now that I cannot see anything, ps...they both show in setup utility. Compaq Pressario V6000.
Normally you can switch between internal and external screen by holding the fn-key Down while hitting one of the function keys with a Screen symbol on (f7 or f8)
Sep 22, 2013 | HP Compaq Presario V6000T Notebook
I cannot shut off the 'fn' key from its calucations display.
If you press and hold the Fn key and then simultaneously press the Num Lock key at the top right of your keyboard you either enable or disable the Alternative Symbols of the following Multi-symbol keys:
Num Lock Disabled: M . / J K L ; U I O P 7 8 9 0
Num Lock Enabled: 0 . / 1 2 3 + 4 5 6 - 7 8 9 *
Nov 18, 2011 | Microsoft Office Professional 2007 Full...
Every time I boot my EEE PC the touchopad is disabled. I plug in a USB mouse, enable the Elan smartpad through the properties of the Elan smartpad and it works ok until I reboot again. How do I enable it...
Usually there is a FN key that will enable the touchpad. I have EEPC and mine is the little blue FN key (usually next to the CTRL and Windows Key) + one of the number keys. Look for a little blue symbol that looks like your touchpad.
As for it being disabled every time you start, I find that very weird. Sometimes installing a wireless mouse, installs software that tells the system to disable the touchpad, so that the 2 don't conflict when using the mouse.
Aug 28, 2011 | Computers & Internet
The touchpad stopped working with a symbol coming up on the screen indicating that the tocuhpad has been disabled. A yellow light indicator is also on by the touchpad. How can I enable it again?...
If you have windows installed you can go to "Control Panel." Select the "Device Settings" tab and click "Enable" to enable the touchpad. Click "OK" to save the changes.
If that does not work. you can press the touchpad for 5 to 10 seconds.
Apr 26, 2011 | HEWLETT-PACKARD ProBook 4320s C Notebook
I have disabled the mlouse by using the synaptics
press the windows button(win logo) on the keyboard left bottom near the Shift key
use the up/dn/left/right arrow keys to move to the control panel/move to mouse icon in that and press enter/ here if the mouse is disabled / enable it
Mar 15, 2010 | Computers & Internet
What switches on the wireless card on X72
IF APPLICABLE WITH FUNCTION KEYS, THERE WILL A SYMBOL OF WIRELESS NETWORK ON THE KEY. PRESS FN WITH THE KEY WHICH SHOWS THE SYMBOL. IF CANT WORK, THEN LOOK FOR THE SWITCH...STILL CNT...THEN GO TO DEVICE MANAGER, LOOK UNDER DEVICES, AND CHECK IF WIRELESS NETWORK IS DIABLED, ENABLE IT..STILL CNT THEN CHECK UR DRIVERS FOR WIRELESS DEVICE AND RE-INSTALL IT..
Oct 16, 2009 | Computers & Internet
Touch pad is disabled and cannot enable it
There will be a function button on the keyboard to turn it on and off, look at all the f1 f2 etc keys and look for a mousepad symbol and press fn + that button.
Jun 19, 2009 | IBM ThinkPad T43 Notebook
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Problem with barcode scanner
Interleaved 2of5 symbologies is normally disabled from factory. what scanning software are you using? have you tried Datawedge to enable the scanner? Is a free download from symbol/motorola and it goes very well.
Mar 05, 2008 | Symbol MC3090
Dell Inspiron 1525 Notebook Logo
613 people viewed this question
Clive
Clive
Alun Cox
