Question about Janome Sewing Machines
Sluggish, tight wheel - Janome Sewing Machines
  • 55 Answers
Machine needs oil. oil all moving parts and wind handwheel by hand for a while to work oil in. if this does not solve problem see a tech for a full service.
scott.
Posted on Jul 27, 2009
Oops. Previous question not detailed enough. Where do I oil my PenCrest sewing machine?
PenCrest is an older mechanical machine. The following may be helpful, even if your machine is not sluggish or stalling, it still needs frequent lube to keep it working smoothly and prevent damage to the motor.
Wheel on right side that controls the needle up and down is very tight...
Mar 09, 2017 | Sewing Machines
Bernette 715 sluggish....I am oiling and running it now. Is there anything else I should do?
check and remove any thread build up around the bobbin carrier and shaft
this thread winds in so tight that it acts like a brake
take it in for a clean and service
Jun 30, 2016 | Sewing Machines
The top tension is way to tight and its turned all the way down. Bought the machine and got it cleaned and oiled sews a beautiful stitch other that the tenison
make sure that the thread is between the tension plates and has not jumped out and is dragging on the thread bolt or springs
Mar 10, 2016 | Sewing Machines
My fuse has blown twice and the hand wheel is tight. How and where do I oil the hand wheel? We are missionaries in Mexico and cannot take it to a repair shop. We have replaced the fuse ourselves. It i
The fuse is blowing because the wheel is tight. This causes an increase of load on the motor which in turn blows the fuse.
I would look at the upper and lower shafts for thread wraps or dirt, properly lubricate the bushings, turn machine by hand and try to find tight spots. no sense putting in a new fuse until the problem is fixed
Oct 21, 2014 | Janome Memory Craft 5700
I removed the hand wheel cover on my Bernina 1001 because the wheel was too tight and now I cant get it to do anything...sew, wind bobbin. Help
With the wheel on you will have a 3 pronged washer, make sure that the screw on the stop motion wheel is unscrewed all the way, put the stop motion wheel back on ans tighten it hand tight only, tighten the screw in the stop motion and see if the stop motion frees off and then tightens again so the machine will work, if it does not take the stop motion wheel of again and move the 3 pronged washer in a different position and put the stop motion wheel back on again
Oct 04, 2013 | Sewing Machines
Why is the hand wheel of my new consew 206rb-5 so tight? the machines hums when sewing, like beeind forced, is this part of the breaking in?
contact the one you bought the machine from & tell them how
tight the hand wheel is & see what they recommend
Jun 04, 2012 | Consew Sewing Machines
Wheel won't stay tight
you might want to have the machine checked about the problem
May 01, 2012 | Sewing Machines
I have an Elnita 250 there is a problem with the wheel, when turning it it does not operate the needle up and down?
Make sure the stop motion wheel is tight, if it will not tighten you will need to undo the stop motion wheel, undo the screw that is in the stop motion wheel, unscrew the stop motion wheel all the way off and you will see a three pronged washer, take the washer off and put it in a different position, put the stop motion wheel back on and tighten to finger tight, screw the screw back up in the stop motion wheel, a final turn one the the stop motion wheel to tighten then test, if it does not work put the three pronged washer in a different position even upside dowm.
Apr 09, 2010 | Sewing Machines
Needle centering wheel is stuck tight and cannot
On these machines, the shaft UNDER the centering wheel fits into a bushing, and this is what normally rotates. The wheel is fixed to the shaft. Penetrating oil needs to be placed UNDER the centering wheel but above the bushing. We solved this problem on two machines by saturating dental floss (the kind used to clean braces) with penetrating oil. Insert the floss UNDER the plastic wheel around the shaft, with the two ends sticking out the slot for the centering wheel. Then cycle the floss in and out of the area around the shaft. Let it soak and repeat. It takes some time, but it worked, and did not require disassembly of the machine. Greased Lightning also was used. Kithen grippers help with rotating the wheel.
May 07, 2009 | Sewing Machines
Sewing Machines Logo
55 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
