Question about Microsoft Xbox 360 Console
Top two red lights flashing on my 360 - Microsoft Xbox 360 Console
  • 90 Answers
To find out whats wrong with your system press and hold the sink button then press the eject button. You need to do press the eject button 4 times each time you do this you will get a series of flashing lights. All four lights meen 0. 1 light is 1. 2 lights is a 2 and so on. Once you get the four numbers you can check online to find out what's wrong with your system. If you are comfortable working with electronics I can help you fix it. Contact me at console.mods@yahoo.com so I can walk you through it.
Posted on Jul 21, 2009
4 Suggested Answers
FixMyConsole
  • 174 Answers
SOURCE: i have one red light on my xbox 360 that is flashing
1 red light usually means a graphics chip problem. A reflow of the graphics processor usually solves this.
Give us a call / shout if you need any assistance.
FixMyConsole
Posted on May 25, 2009
Bay Ridge
  • 102 Answers
SOURCE: my 360 keeps on flashing 3 red lights what
Hi Susie,
This may be an indicator of a problem with the Xbox 360's hardware. To help confirm this, turn on your console and check the power supply (the big gray brick) light. If the light on it is red, orange, unlit or anything other than green, make sure it's plugged in correctly. If that checks out, try a different outlet. If it still doesn't work, you'll have to buy a new power supply for it.
If the light is green, then you definitely have a hardware problem. The only way to resolve this is to go to this site where you can ship the 360 in for repairs. If you've bought the 360 less than 3 years ago, the repair will be of no cost to you, and Microsoft will even provide the box.
If it's been more than three years since you've purchased your 360, I believe it will cost $93 to have it repaired.
Hope this helps :)
Posted on Nov 29, 2009
  • 26 Answers
SOURCE: my xbox 360 top left light is flashing red
Its is most likely a Audio/video connection problem which is caused by a bad cord. All you need to do is change it!
Posted on May 05, 2010
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Desk top not coming up red light flashing on front
hi , the only thing ull have to do is take it in , it shows red light it has basically crashed . It happens to all x box 360 at least once a year .Sometimes twice depending on usage , dont think it cost anything ,just postage to xbox factor and it will be returned .Cll in to ur nearest gaming centre and the will sort it,or google xbox for details hope i answered ur question
Nov 06, 2010 | Microsoft Xbox 360 Console
Red flashing lights
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Nov 16, 2009 | Microsoft Xbox 360 Console
I have three red lights flashing
Well you're either in luck, or in deep trouble. If you have bought your xbox 360 within 3 years, you have a special warranty provided by Microsoft. Call them or go to their support site, and list the problem as having three red light flashing. IMPORTANT it has to have 3 red flashing lights, with only the top right not flashing to have the warranty. They will send instructions and a box, and you just have to wait
Nov 07, 2009 | Microsoft Xbox 360 Console
XBOX 360 TWO RED LIGHTS FLASH
the two flashing lights is the code for your console overheating make sure nothing is on top of or behind the xbox and make sure it is not in an enclosed space
Sep 20, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
RED RING WHEN TURNED ON OFF FOR A WEEK
Nov 26, 2008 | Microsoft Xbox 360 Console
Xbox 360
i order to fix the 3 red lights on your 360 u must take it apart all of it and then clean it from top to bottem and then put back together when the light s flash it does not mean your 360 is broken ight it just means you need to clean it
Oct 31, 2008 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
146 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
