Question about Amana SXD524VW Side by Side Refrigerator
Freezer not getting lower than -20deg
1996 amana SX25SW the freezer not getting lower than 20deg and ice forming on the line coming out of the compressor. It seem like the defroster is coming on before it gets to 5deg it goes back in to the 30's.
  • Samuel Charles Spriggs May 11, 2010
    Sounds like possible low refrigerant charge.
  • 614 Answers
Three things bad defrost time bad defrost termination switch or bad heaters. You need aservice tech to check this out. Russ
Posted on Jul 19, 2009
Freezer not cold and forming ice in side?
Replace the defrost thermostat located on the coils in the freezer. Here is the part to order.
Dec 03, 2012 | Amana ARS2464B Side by Side Refrigerator
Amana refrigerator freezer access panel removal
As a plumber... I would initially want to see if it is indeed a leak from the water line. You have defrosted, so there would be water at that time and a short period thereafter. You have had the unit off for two days so it's not been able to "generate" any more ice or even had a chance to malfunction and "try" open the solonoid valve and allow water into the ice maker or water dispenser.... All that being said...
I suspect the water you're see is ultimately from the incoming (pressurized) water line... probably not from the actual ice make line coming into the fridge, but more than likely somewhere "within" the piping of the fridge itself... its very possible something was accidentally damaged during the previous process you just went through-- especially if you removed the door to the freezer. Many fridge's have the water line come through the lower side hinge of the freezer door, not sure if this is true in your case.
Hope this helps, if not it may be applicable to someone else... good luck!
May 17, 2012 | Amana Refrigerators
Compressor line going to freezer is iced up. won't get lower than 25 degrees.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice forming on bottom of inside of side by side AMANA refrigerator / freezer and leaking on floor
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 18, 2009 | Refrigerators
Ice is forming in the freezer due a small hole formed the freezer door.some say that the gas is leeking so it happens any solution?
you must close the hole otherwise you will always see the frost.Humid air comes from outside and creates the frost.Change the door gasket.Be sure it seals good.
Jun 23, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana sx25sw - side by side - fridge not cooling
might be as simple as bad defrost timer( 10530703 $50)and/ or defrost thermostat(R0161088 $35), replace em both for under a hundred bucks. the timer is found behind the kickplate lower right hand side and the derfost thermo is wired in behind the rear panel atop the evaporator, and yea your right its preventing flow cause you "self-defrost" isnot functioning.Great frig though Id fix it
Nov 04, 2008 | Whirlpool GS6NBEXR Side by Side...
Water from core is getting into my freezer
Right, the drip tray on the upper coil section has a blockage (possibly mold) that prevents the defrost condensate from reaching the evaporator pan that should be at the bottom of the fridge. Those lines are usually accessed from the back of the fridge.
Jun 19, 2008 | Amana ARB220RCW Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Amana SXD524VW Side by Side Refrigerator Logo
230 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
