Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
70's snapper comet, 8hp B&S, when trying to start runs for a second and quits, like non steady flow of gas. cked gas flow to carb, OK. There is a very fine spring attached to one end of the ? (wire from throttle to carb)thar is not attached at the carb end. Where does it attach and could this be the issue? Mower quit in mid mow.
  • swan0557 Jul 19, 2009
    I disconnected the hose from the tank to the carb, solid flow. The issue is in the carb. I choke it and run the throttle back and forth, gets just enough gas in the carb to run for a second, not continuous. Perhaps the float is sticking or some garbage plugged in the needle. Thoughts
    need more info, have good flow to the carb!!
  • 8,220 Answers
If it is trying to run it is starvin fer gas, get the gas tank off and dump its contents. Clean out the dip tube screen.
Posted on Jul 19, 2009
Why wont my z150 snapper start
It sounds very much like the carburetor's float valve is stuck shut, not allowing gasoline to enter the carburetor. Try tapping on the side of the carburetor several times with a screwdriver handle while a helper cranks the engine.
It's also possible that the choke isn't closing for a cold start, or that someone has fiddled with your idle mix screw, turning it fully closed. If you're SURE that nobody has tampered with the idle mix screw, it may be time to pull the carburetor off for a thorough internal cleaning & possibly a rebuild kit.
Jul 23, 2014 | Snapper Garden
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
Jul 07, 2012 | Honda 8 HP Engine
Won't start
while changing the line you may have got dirt into the carb
Apr 05, 2012 | Garden
I have a tecumseh 8hp on a snapper handlebar rider. bought it used 2 weeks ago, got it home mowed for about 1 hour and it quit. decide to give it a tune up. noticed the coil wire was almost burnt in half....
If plug is dry than you are not getting fuel to the plug something is plugged up in the carb clean it thoroughly and make your coil gap is correct. But I would lean more towards the fuel not reaching the plug.
Jul 18, 2010 | Garden
20 hp craftsman lawn tractor (2006) stopped running while mowing. tried to restart . ran for 2-3 seconds and quit. could not restart. fuel running free through filter all the way to carb. pouring fuel in...
I would take the bowl off the bottom of the carb.. Probably you have clogged up holes that let the gas into the bowl.Or either the needle is stuck up not allowing the gas to flow...That's why pouring gas in carbs would let it run for s few seconds....Also try fresh gas..Gas doesn't have led in it anymore..It don't last year from year...After grass season is over..Buy some from Lowe's or home depot..Pour it into your tank and let the motor run to get it done into the carburetor...Then the next year it will start
Jan 12, 2018 | Craftsman 20 Hp 42" Deck Lawn Tractor
Engine runs then quits
You may have a small air leak at the carb, sometimes found at the bulb primer. This allows the engine to stop picking up fuel due to sucking air into the fuel line. If you re-prime, it will run again for a short period?
Apr 15, 2010 | Garden
Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
Need linkage diagram for 6HP briggs carb from snapper comet mower
Try looking up your product here: http://www.snapper.com/manuals/
If you can't find what you need there, please try to contact Snapper at: http://www.snapper.com/contact/
If it's the linkage on the engine itself, try Briggs & Stratton's website here: http://www.briggsandstratton.com/maint_repair/manual_and_more/
Hope that helps!
Apr 30, 2009 | Snapper Electrical Supplies
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
150 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
Dan Webster
Dan Webster
John Trevino
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
