Question about Craftsman 24 Hp 48" Deck Yard Tractor
Engine wont fire has spark gas not getting thruogh
Craftsman lawn tractor engine wont fire has spark gas not getting thruogh carberator model dlt 2000 briggs engine model 445777 type 0154 ei
  • Anonymous Mar 31, 2014
    Engine will not start
    Relay issue.
  • 475 Answers
Pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Posted on Jul 25, 2009
How to fix lawnmower
what wrong with it if it wont start check for spark at plug if works try squrting starter flood into carb if tries to start rebuild carberator tecuseh engines are bad about clogged up carb with dirt
Aug 16, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Need to locate the safety switch on a craftsman dlt 2000 lawn mower
witch switch do you need the one near the brake/clutch pedal the one on the seat the one on the the one on the trans for mower deck reverse cut out?
Jul 13, 2012 | Craftsman Garden
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Adjusting a craftsman dlt 3000 riding mower carberator so it will not flood engine
assuming that you are working on a briggs engine? regardless of make what the problem is that the needle and seat inside the carb is not sealing off the fuel flow from the fuel pump/fuel tank or both......gravity feed fuel systems are the worst about flooding, the only fix will be a carburetor repair with needle and seat replacement
Nov 25, 2009 | Craftsman Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
NO SPARK, SPARK PLUG GOOD,COIL GOOD AND CARB. GOOD, IS THERE A SAFETY SWITCH SOMEWHERE CAUSING THIS?
Hi..my name is Keith..and to answer your question..Yes there is several safety switches that will keep your engine from starting..i would check the seat switch..the neutral safety switch and the blade engaged switch..the clutch/brake switch...if all these check good..then write me back and i will help your further
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Best oil to use in tractor lawn mower
Always use straight 30W oil in small four cycle engines if they are not liquid cooled. Use a brand name single weight 30 viscosity oil.
Mar 16, 2009 | Briggs & Stratton Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
481 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
