Question about Edimax 4 Port Wireless AP Broadband Router (br-6104wb)
How to configure 4 port router - Edimax 4 Port Wireless AP Broadband Router (br-6104wb)
  • minespress May 11, 2010
    You really need to put up more information than this.
    For most home users, there is nothing to configure on most routers. You plug the internet into the "internet" or "wan" port, and your computers into the other ports.
    Scholar:
  • 25 Answers
If you just purchased and opened the box-
1- open your package and take out the instructions on what do to for setting up (not the manual)
2- connect your modem (source of internet) to the internet port of your router with the cable provided by your router packaging.
3- with the other available cable (that you already had) connect to one of the 4 ports (prefferably port #1) and the other end to your PC/Mac
4- If everything was powered on already during the connection of all these cables, you can to unplug the power to the internet modem (source of internet connection) and your router now.
5- Plug in the Internet Modem power to the wall and wait 30-45 seconds... then plug the power to the router and wait another 30 seconds.
6- now, try to go on the internet with your computer.
7- if it still doesn't work, just restart your computer 1 time
8- If it still doesn't work after you restarted your computer (very important to do this 1 time after following abpve steps), check the router's instructions for troubleshooting tips and follow up post us where you're stuck and provide to us:
What model router you're using, PC model and which Windows/Mac Operating system you're using. :)
Please rate us. :)
Posted on Jul 19, 2009
  • Mc Tech 2000 Jul 19, 2009
    step 8 typo, (very important to do this 1 time after following above steps),
How to config vlan on switch 3cdsg8 and a router draytek 2920
You can configure trunks TRUNKS > Configuratio
n.
You can configure port to be part of that truck via TRUNKS > Members
Jun 16, 2014 | Draytek Computers & Internet
I have set everything up but its not working. The computer is showing a full bar, but the internet connection is saying its not connected.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cable connections/router support
  • make sure that the modem has internet when connecting directly to the PC.
  • or else call your ISP
  • if internet is ok, check the cable from modem, is connected to the WAN/internet port/isolated port of the router,
  • then the PC is connected to any of the 4 ports of the LAN ports of the router,
  • then call your router brand manufacturer support to configure your router if the connection still to configure your router to get IP address from the modem
Aug 12, 2009 | Computers & Internet
Can not get it to connect i have checked all cables and made sure they are connected tighly and right and it still does not work
  • then call Linksys to configure your router if the connection still to configure your router to get IP address from the modem
Aug 11, 2009 | Linksys Wireless-G WRT54G Router
Woodenthings
Your provider probably sent you either a cable modem or adsl modem. If you connect the single port on the modem to the WAN or Internet Port on the Linksys and then connect the computers to any of the 4 ports that are grouped together, it should work.
Mac or PC, it makes no difference and drivers are not needed.
Unless this is a new router or it is one that you personally configured, I recommend resetting it back to factory default by holding down the little red button for 30 seconds, this eliminates any configuration issues that someone else may have introduced.
Jan 03, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Reconfigure as a WAP only
Do not use a cross over cable, use a normal cat5 patch cable connected from one of the lan ports on the other router to the wan port of this router.
Configure this router to obtain ip address automatically (like it would be configured to connect to a cable ISP)
Turn off DHCP on this device.
That should do it. If it does not, let me know because some router want a static route configured.
If you want 2 seperate networks with internet access, leave the dhcp on but change the internal address so that it is different from the other router.
ie: if the other router is 192.168.0.1, this one can be 192.168.x.1 (where x is anything but 0)
Oct 14, 2008 | 2wire 1800HG Router (RG1800HG00)
Dual Routers?
Disable DHCP in the router. Connect the modem to a LAN jack on the router. You'll have 3 LAN ports. If you need more ports, buy a hub. (You can change the default IP address on the Linksys, but you can't forward through 2 NATs.)
Apr 27, 2008 | Computers & Internet
Cant get decent speeds from u torrent
I recommend checking out http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
This is a great tutorial on configuring port forwarding on your particular router. This example is for emule but it will be very similar to uTorrent. You will want to determine what port uTorrent is configured to send data on and use that accordingly.
Jacob
Mar 18, 2008 | Belkin (F5D7230-4) Router (587009)
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
Feb 19, 2006 | NetGear FM114P Cable/DSL ProSafe 802.11b...
Edimax 4 Port Wireless AP Broadband Router (br-6104wb) Logo
246 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
